Neilj99 Occasional Visitor
Posted: Thu Oct 25, 2007 10:46 pm Post subject: Where's me POIs - yikes |
I've tried both methods of downloading the POIs.
I've copied the zip contents over to the western europe folder.
Home shows the downloads on the device on the explore screen, however, when on the enable POI screen on the device, they are nowhere to be seen.
Why is this?
Neil
GO 910 ver 6.525 |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Oct 26, 2007 12:41 am Post subject: |
Quote: | I've copied the zip contents over to the western europe folder. | Did you remember to unzip the file and copy contents from the newly created folder? |
Posted: Fri Oct 26, 2007 12:46 am Post subject: |
Sure did. |
Posted: Fri Oct 26, 2007 12:51 am Post subject: |
I've read other posts where it's recommended you don't use Home, so try copy and paste the files directly to the map folder you are using. |
Posted: Fri Oct 26, 2007 12:57 am Post subject: |
Thats what I did. I merely remarked that the POIs appeared in the Home explore screen. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Fri Oct 26, 2007 1:33 am Post subject: |
have you gone over the 100 poi category limit?
anything over the limit will simply not show
MaFt |
Posted: Fri Oct 26, 2007 1:41 am Post subject: |
The only categories in the unit are the built-in 910 poi's and the latest complete zoned pocketgps cameras. |
Oldboy Pocket GPS Moderator
Posted: Fri Oct 26, 2007 6:59 am Post subject: |
Have you copied them into the right Map Folder? _________________ Richard
Posted: Fri Oct 26, 2007 1:37 pm Post subject: |
Sure did. |
Posted: Fri Oct 26, 2007 3:45 pm Post subject: |
Have you tried a Reset? It might work. _________________ Richard
Posted: Fri Oct 26, 2007 5:10 pm Post subject: |
*hides head in embarrassment*
I double-checked what Home said was installed, and realised I also had the Tomtom specific cameras loaded for the *whole* of Europe (in addition to the PGPS cameras), not just the UK. I've removed all the other European cameras and the PGPS POIs popped into action.
Thanks for all your suggestions.
Neil |
Posted: Fri Oct 26, 2007 6:14 pm Post subject: |
You're not the first, and I doubt whether you'll be the last. _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Sun Oct 28, 2007 9:20 pm Post subject: |
So to summarise....
Count the number of .ov2 files in your map folder, using Windows Explorer. IGNORE anything 'Home' tells you.
More than 100 .ov2 files = missing POIs. |
