Geoff_UK Regular Visitor
Joined: Feb 10, 2006 Posts: 101 Location: North East England
Posted: Thu Oct 25, 2007 5:00 pm Post subject: New TomTom Home version |
Plugged in today and was offered version 2.1.1.106 to install.
I was using the previous version (2.1.0.92) and had mapshare working and had downloaded several map updates and poi updates.
The previous version (2.1.0.92) seemed to stop working a couple of days ago and the update screen stayed on for ages until it eventually said "your session has timed out".
Not having much luck re updates with this "new" version either  _________________ tomtom one v2 - 7.162
2Gb Toshiba SD card
UK and IE plus major roads of WE - v675.1409 |
xda Lifetime Member
Posted: Thu Oct 25, 2007 5:37 pm Post subject: |
Just got it offered as an update about an hour ago. Been having a play, seems pretty stable. MapShare works from within Operate My Go just updated a few more everything else seems to work as well as the V2.0 _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Thu Oct 25, 2007 5:43 pm Post subject: |
"operate my go" works - took a couple of attempts to download the required file, but I still can't update the device  _________________ tomtom one v2 - 7.162
2Gb Toshiba SD card
xda Lifetime Member
Posted: Thu Oct 25, 2007 5:49 pm Post subject: |
I see you are using the One, I think there is still problems within the map version you have that is not allowing the MapShare function to work as it does on the Go720's _________________ Graham.
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Thu Oct 25, 2007 6:36 pm Post subject: |
Mapshare POI's still not working on my 720 with this version. |
Posted: Thu Oct 25, 2007 9:03 pm Post subject: |
xda,
I was using version 2.1.0.92 for a few days and mapshare was workin as far as I could tell - I was getting map corrections and poi corrections.
It stopped woring a day or so ago and kept timing out when doing an update.
Sadly, the new one don't seem to work now either  _________________ tomtom one v2 - 7.162
2Gb Toshiba SD card
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Thu Oct 25, 2007 10:43 pm Post subject: |
updated now it's working again finally ....but for how long _________________ TomTom 5001 |
oldfogy Frequent Visitor
Joined: May 08, 2006 Posts: 252 Location: West Midlands. UK
Posted: Thu Oct 25, 2007 10:48 pm Post subject: |
Re: New version of TT Home.
BE CAREFUL!
Not only backup your TT, but also backup your PC.
Having just been offered, downloaded and installed the latest version, first of all it said a file that was required is not yet available. So that to me means it is not going to function properly, so I might as well get rid of it.
So no problem thought I, I'll just do a system restore back to the previous version, er, restore worked okay but did not restore home back to the previous version, however the now the fun and games start.
M$ Add or remove programmes can't delete it for some particular reason (something to do with one of the files not being recognised).
And it's own Uninstaller would not work for the same reason.
Okay, again no problem, just re-Ghost the PC, (no problem)
However it then becomes impossible to do a TT Home restore because some of the files that have now been altered on the TT were altered with the newer version and the older version will not allow it to be restored.
Fortunately I still use the "OLD" TT backup program from-time-to-time and that let me restore the system.
However the fun "if you can call it that" does not stop there, as I have all these backups etc on my D: drive along with saved files from the TT, some of the altered files still exist and it then means finding those, deleting them and then replacing again from the TT to the PC (Maps, Voices etc)
However, back to the original new download.
I personally don't think the layout is a good as the previous version. _________________ (If it ain't broke, I can soon fix it) |
Ray-of-Sunshine Regular Visitor
Posted: Fri Oct 26, 2007 12:45 am Post subject: |
I've now upgraded to the newer version as well but still not having any joy either. |
DennisN Tired Old Man
Posted: Fri Oct 26, 2007 1:01 am Post subject: |
oldfogy wrote: | I have all these backups etc on my D: drive along with saved files from the TT | You lucky so and so - my D: drive is currently playing dead (rather convincingly)!!  _________________ Dennis
Two of them are obesiting!! |
xda Lifetime Member
Posted: Fri Oct 26, 2007 1:18 am Post subject: |
Geoff_UK wrote: | xda,
Sadly, the new one don't seem to work now either  |
As I said previously I think your problem is the map version you are using with your TT One which is different to the map version being used on the 720, a few days ago TT made a new home version 2.1.0.92 available but my home version 2.0.0.370 wouldn't see that as an update, as I mentioned to Andy I think that was a home update for the TT One's using the v7 map update. Last night my home picked up the Home V2.1.106 and everything is still working correctly.
I think the problem lies in the fact that TT are running 2 separate update programs 1 for the TT One and 1 for the G520/720 and the home versions intended for the 720's are being picked up by you guys using the TT Ones.
Try seeing if you can revert back to the previous version that worked for you. v2.1.0.92 If you don't still have I did download it but never installed it
so could email it to you if you give me an email address. _________________ Graham.
xda Lifetime Member
Posted: Fri Oct 26, 2007 4:03 am Post subject: |
technik wrote: | Mapshare POI's still not working on my 720 with this version. |
Try this, with your 720 in it's cradle, turn it on and you should have Home start up.
Go to preferences, MapShare select POI categories, deselect all the POI's you don't want to update, it defaults to all. select Done.
The ones I'm using are:-
Sorted Numerically:
7310 Car repair/garage
7311 Petrol station
7321 Hospital/clinic
7322 Police station
7326 Pharmacy
7380 Railway station
9373 Doctor
9374 Dentist
9910 Car dealership
Go back to preferences, MapShare, remove corrections, tick the second option Remove all corrections made by others.
Select Done.
Go to File, Log out, turn off the Go720 wait a few seconds then shut down Home
Turn the Go back on let Home load select the device memory It should then go to the update screen and show both map and poi updates available select update.
From My Computer go to TomTom drive, Western_Europe open the map folder if it all worked you should see a number of CA****.ov2 files corresponding to the number you selected.
Also check that your Mapshare settings on your Go are the same as here.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=60504&highlight=
in reply to Tims question.
I used this method earlier to reduce the number of Mapshare updates ie CA****.ov2 files from 68 to 9 in my map folder. _________________ Graham.
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Fri Oct 26, 2007 7:09 am Post subject: |
oldfogy wrote: | So no problem thought I, I'll just do a system restore back to the previous version, er, restore worked okay but did not restore home back to the previous version, however the now the fun and games start. | System Restore only works on the Registry, not installed programs.
oldfogy wrote: | M$ Add or remove programmes can't delete it for some particular reason (something to do with one of the files not being recognised).
And it's own Uninstaller would not work for the same reason. | That's because the Registry was reset to a time prior to that HOME being installed, so there is no reference to it.
oldfogy wrote: | Okay, again no problem, just re-Ghost the PC, (no problem)
However it then becomes impossible to do a TT Home restore because some of the files that have now been altered on the TT were altered with the newer version and the older version will not allow it to be restored. | One good reason why most users don't use HOME for Backups.
I know it's a bit late now, but the better method would have been to Uninstall the HOME first, and then do a System Restore. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Fri Oct 26, 2007 12:22 pm Post subject: |
Oldboy wrote: | One good reason why most users don't use HOME for Backups.  | Yes I must admit it is pretty naff and takes far to long, it's much quicker just doing a copy (drag and drop) of the whole SD card.
Oldboy wrote: | I know it's a bit late now, but the better method would have been to Uninstall the HOME first, and then do a System Restore. | I think I may of done something similar on those lines but the main problem came about because TT actually altered (updated) some of the saved files on the D: drive (which is not set for restore points as it is tooo big). Plus as you rightly say, restore operates the registry not the installed files.
But thanks for your replies, they are much appreciated.
However my faith in TT has now taken a BIG dive. _________________ (If it ain't broke, I can soon fix it) |
Posted: Fri Oct 26, 2007 9:33 pm Post subject: |
xda wrote: | From My Computer go to TomTom drive, Western_Europe open the map folder if it all worked you should see a number of CA****.ov2 files corresponding to the number you selected.
I get the CAxxxx.ov2 files but that is all.
I cannot view them anywhere on my 720, so it's all pointless. |
