mikelds Occasional Visitor
Posted: Sun Oct 21, 2007 10:02 pm Post subject: mp3 on TT520 |
I have got a TT520 and am unable to get the SD card recognised when in the Tom Tom although TT Home recognises it. I am using a standard Kingston 512 card that worked ok in my TT500.
I have reformatted the card as FAT32 installed the application and created a folder mp3 (lower case) on the card.
When the SD card is in the unit it gets to the tomtom picture screen then turns off and tries to reboot then goes off again
Apparently when turning on it checks if there is an Sd card in first if not it uses the internal memory information. If I put the SD card in when the unit is on and turn the unit off a grey blank screen appears for about 20 seconds then goes off.I have tried reformatting again but when checking for updates it does not now offer the option to download the application. Is there a link so that i can download it another way?
I am wanting to put mp3's on my card.
Anybody else come across this
mikelds |
Posted: Sun Oct 21, 2007 10:11 pm Post subject: |
I have tried loads of memory cards in my 720, I only appear to have two that will work with it!
Most of my cards are Kingston and the 720 seems to reject them on boot up, I should add the memory cards I have are from a couple of years ago, the newer ones seems to work as I purchased higher speed cards.
Do you know what speed the cards are in terms of read/ write? - Mike |
Posted: Mon Oct 22, 2007 12:45 am Post subject: |
Hi Mike
Dont know the read/ write speeds
My card is also a few years old
What cards do actually work ?
Am i doing the right thing by installing the application on the SD card?
If so where can i download the application as it no longer shows up in home |
Posted: Mon Oct 22, 2007 7:57 am Post subject: |
With the x20 you do not need the application on the card as the unit will use both the internal flash memory AND the storage card when inserted. I only use my SD card for music, for this simply create a folder called "mp3" (no "" in the folder name), this folder needs to be in the root of the memory card, then place your mp3 tracks/ folders in it.
Another use for the memory card is additional maps, sadly at the moment Audio Books have to go on the device as they will not play if mounted on the memory card.
As for which ones work, get a good high speed card, not the cheaper ones from e-bay etc - Mike |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Mon Oct 22, 2007 10:13 am Post subject: |
I have an Integral High Speed 2Gb card in my GO520, but I only have maps on it, no mp3 files. It works fine, though. _________________ Tim |
Andy_P Pocket GPS Moderator
Posted: Mon Oct 22, 2007 5:07 pm Post subject: |
One little thing to be aware of....
As others above have said, as well as using the SD card to REPLACE the internal Flash Memory (if present) on any model; on the 520 and 720 ONLY, you can also use the SD card as additional storage for mp3s etc.
If you have got a card in the slot at the time you re-boot the TomTom, the first thing you will see on screen is a graphic showing the SD card with a red cross through it. This does not mean it is no good, just that the program wasn't found on it so the system is moving on to find it on the Flash memory. |
Posted: Mon Oct 22, 2007 11:04 pm Post subject: |
Thanks for all your replies.
It would be good to know what other SD cards work
Maybe start a listing |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Tue Oct 23, 2007 12:37 am Post subject: |
I (temporarily) used a Transcend 150x 2GB card for mp3s successfully. _________________ Dennis
Two of them are obesiting!! |
marshall Regular Visitor
Joined: 01/09/2003 10:29:35 Posts: 113 Location: Lancashire
Posted: Tue Oct 23, 2007 8:32 pm Post subject: |
Hi all
anyone know if the newer sdhc cards will work?
marshall _________________ marshall TomTom Go 520 , Western Europe v805.1801 map. app 8.2204- v7KATE 4gb sd card + other cards |
Posted: Tue Oct 23, 2007 9:53 pm Post subject: |
I have an 8GB SDHC card installed and working very well on my 720, it is idented as a class 6 card manufactured by "PEAK" - Mike |
Posted: Wed Oct 24, 2007 8:56 am Post subject: |
HI Mike
mikealder wrote: | I have an 8GB SDHC card installed and working very well on my 720, it is idented as a class 6 card manufactured by "PEAK" - Mike |
thanks for that i'ii have to get one
Posted: Wed Oct 24, 2007 9:03 am Post subject: |
I got it from CPC in Preston near the M55/ M6 junction - probably fairly local to you? price around 52 quid - Mike |
Posted: Wed Oct 24, 2007 3:30 pm Post subject: |
mikealder wrote: | I got it from CPC in Preston near the M55/ M6 junction - probably fairly local to you? price around 52 quid - Mike |
thanks mike _________________ marshall TomTom Go 520 , Western Europe v805.1801 map. app 8.2204- v7KATE 4gb sd card + other cards |
