rodlus Occasional Visitor
Posted: Fri Oct 12, 2007 8:10 am Post subject: HELP!!!!!!!!! |
I have an o2 xda2i I have bought a gps module to plug into it but my software reports no gps receiver found. Does anyone have any suggestions. |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri Oct 12, 2007 1:40 pm Post subject: |
Bit more infor please...
What gps 'module'? What OS is the PDA running?
And  _________________ Phil |
Posted: Fri Oct 12, 2007 2:23 pm Post subject: |
If it is a cabled GPS device that is using the serial com port on the unit go to Start Settings/ Connections tab and select Beam, now de-select the "receive all incoming beams" check box and try the GPS again.
The iRDA port uses the same serial com port on the XDA so when it is switched to iRDA mode (which is by default) the unit cannot see the GPS receiver when powered and connected - Mike |
Posted: Mon Oct 15, 2007 5:28 am Post subject: |
my xda2i is running windows mobile 2003 se my gps is a sg949 |
Posted: Mon Oct 15, 2007 1:50 pm Post subject: |
rodlus wrote: | my xda2i is running windows mobile 2003 se my gps is a sg949 |
As it is a cabled device - see mikealders response above _________________ Phil |
