Anita Pocket GPS Moderator
Posted: Thu Oct 11, 2007 10:31 pm Post subject: ov2 files added by Mapshare |
First an apology, as I'm sure this has been covered before, but I can't find it.
I've just downloaded updates via Home 1.6, and then checked the 720 in Windows Explorer. There are 58 files CAnnnn.ov2 . Do these count towards the 100 maximum POI categories, and are they required files? Surely the new/amended POIs have been added to the relevant categories' ov2 files. Are am I completely misunderstanding the way it works? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
sgould Frequent Visitor
Posted: Thu Oct 11, 2007 11:15 pm Post subject: |
I think you will lose access from some PoIs as the mapshare ones accumulate They do form part of the 100. I believe that TT have conceded that it's a "bug". _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Thu Oct 11, 2007 11:36 pm Post subject: |
sgould wrote: | I think you will lose access from some PoIs as the mapshare ones accumulate They do form part of the 100. I believe that TT have conceded that it's a "bug". |
Thanks, sgould. That really is a bug, as it uses up more than half of the available POI categories. I hope TT are working on a solution.
It probably explains a problem I've been having tonight. After reading a thread about the limited number of Favourites I added a new POI category to put them in instead. When I tried to add POIs to the new category it didn't show, but it appears when I browse the TT in Home and Explorer.
I'll have to try deleting one of the categories I don't use much and see if my new one is then accessible. _________________ Anita
UK map 1130.12368
Posted: Fri Oct 12, 2007 8:02 am Post subject: |
The alternative is to disable the POI updates that are supplied via TomTom Home, this reduces the number of ov2 files that "grow" on the device, the map data ones do still clock up but only a few whereas the POI Updates can consume 50 to 60 ov2 files in one hit!
Until TomTom speed up the process of vetting/ adding the submitted POI to the downloads I have decided not to use this option on a couple of my units because of the unpredictable behaviour it results in messing up custom POI files. A real shame as Map Share is a great idea, sadly let down by poor implementation, oh and the fact it needs the TT Home package to function is a very big black mark in my opinion. - Mike |
Posted: Fri Oct 12, 2007 8:53 am Post subject: |
Is it OK to delete these files? If so, presumably there's no way of telling which updates are POI and which are map. If map updates are deleted do you think the'll be reapplied next time I connect to Home?
I counted up the ov2 files, and I had 116. The 58 update files and the 37 Speed Zoned pgpsw files come to 95 already, so I've removed all but 4 of my custom POIs. As all of the CAnnnn files have yesterday's date I assume they are overwritten rather than added to. When I enter Navigate to - POI I have 98 categories to select from, and taking away the custom ones leaves 57 TT ones so, if the map and POI update files are overwritten each time, all of them have been updated, so hopefully they won't increase further!
I'll watch the updates before deleteing anything else. _________________ Anita
UK map 1130.12368
Andy_P Pocket GPS Moderator
Posted: Fri Oct 12, 2007 2:52 pm Post subject: |
What I've learnt so far...
The CAxxxx.ov2 files are INCOMING updates to the built-in POI categories. One for each of their categories. They do indeed overwrite earlier versions.
The PAxxxx.ov2 files are OUTGOING updates to POIs (and possibly Map corrections) that you have made.
So if you subscribe to updates to ALL their categories you lose upto 58 POI 'slots'.
I have now deleted all the CAxxxx files and started again, having unticked most of the updates (like Mountain Passes, the ludicrous 'shops', etc.
Incoming corrections for the actual map are dealt with differently. There is a post somewhere on one of the forums where someone logged what files were added/changed but I've mislaid it for the moment. |
Posted: Fri Oct 12, 2007 3:55 pm Post subject: |
Thanks for that info, Andy. Very helpful!
I'll delete the files and only download updates to the TT categories I'm likely to use. _________________ Anita
UK map 1130.12368
bunnyman69 Regular Visitor
Posted: Sat Oct 13, 2007 1:20 pm Post subject: |
i been updating my 720 regular but i dont see any of these .ov2 files other than my own and pgps ones. What folder are you looking at, i'm just checking the western europe one? |
Posted: Sat Oct 13, 2007 1:30 pm Post subject: |
no need to answer, i found out myself that its preferences on HOME/MAPSHARE /subscribe to POI corrections. Just done about 6 that i may use and now see the additional CA***.ov2 files in my western europe folder |
