jonf Occasional Visitor
Posted: Tue Oct 09, 2007 4:44 pm Post subject: TT ONE V3? problem. |
Could anyone tell me how to install the camera database - have a TT one V3 - have downloaded the database, but TT says that there is no map to download to!!!!. Installed OK with V2 - new TT is V3. |
Posted: Tue Oct 09, 2007 4:55 pm Post subject: |
Firstly is this the database from TomTom or this site? - if it is the latter try this method:
Download the ov2 format database, unzip it and copy it to the map folder on the device, use Windows Explorer to copy the files to the device as it is the most reliable method. - Mike |
Posted: Tue Oct 09, 2007 5:04 pm Post subject: |
Thanks for the reply - however, TT Home is saying that there is no map - TT V3 dosnt have a card - all internal!! - could this be the problem?
PS database is from THIS site. Unziped and no probems with V2. |
Posted: Tue Oct 09, 2007 5:14 pm Post subject: |
Try what I suggested in the above post using Windows Explorer to view the TomTom Drive on the PC, if you click the drive letter it will open to reveal a list of folders, the map folder should be apparant from the folder name "Western_Europe" or "United_Kingdom_and_Republic_of_Ireland"
If you cannot see the TT device via Windows Explorer what OS is on your PC? - Mike |
Posted: Tue Oct 09, 2007 5:26 pm Post subject: |
Have posted into TT map file - they appear in the map folder - do I need to activate? There are 6 files posted! Do I just need the CAB file? |
Posted: Tue Oct 09, 2007 5:42 pm Post subject: |
Download the TomTom ov2 speed camera set unzip and install that, the TomTom Home download is a different animal all together - Mike |
Posted: Tue Oct 09, 2007 5:54 pm Post subject: |
Contined within the map file is the database (bitmap and OV2 files). OS is Vista. Apologies for being sutch a pain. |
Posted: Tue Oct 09, 2007 6:12 pm Post subject: |
OK so you now have the required files in the map folder on the device, use the TomTom and select Warn When Near POI, select each of the pocketgps camera POI files in turn and set up the warning distance, sound and warn only if POI on route check box as per your preferences - Do this using the device NOT TomTom Home then it will warn you of cameras as you drive around - Mike |
Posted: Tue Oct 09, 2007 6:27 pm Post subject: |
Cant see the POIs in/on my TT - only what came with the TT (police station, post office etc). |
Posted: Tue Oct 09, 2007 6:34 pm Post subject: |
When the TomTom is connected to the PC and you view the map folder using Windows Explorer do the pocketgps POI files appear listed within the folder, they need to be contained within the map folder and not within any sub folder or CAB file - Mike |
Posted: Tue Oct 09, 2007 6:45 pm Post subject: |
Speed-zoned files are within the map folder. |
Posted: Tue Oct 09, 2007 7:18 pm Post subject: |
If the speed camera files are being made available on the device can you count up how many POI files are within the map folder, look at the folder using Windows Explorer and count up the number of files ending with .ov2 as these are the Custom POI files, there is a limit of 100 - Mike |
Posted: Wed Oct 10, 2007 7:59 pm Post subject: |
Thanks for the above advice. Used the TT today and found that some camera locations do in fact warn! - havnt entered any proximity alerts etc!! - very strange. Still cant find any notification on the TT devise though. |
Posted: Thu Oct 11, 2007 6:02 pm Post subject: |
Hi Mike, took your advice and looked at the page you submitted - did what was asked - wasnt sure where the "root" directory was though (please give more info), tried a few possibilities - no lock!! With refrence to the camera alerts - also no joy!! will try agains shortly (non of the above was a problems with my old V2). |
Andy_P Pocket GPS Moderator
Posted: Thu Oct 11, 2007 6:15 pm Post subject: |
The "root directory" is an old computing term. It means "not inside any other folder" (also known as a 'directory').
So, on your PC hard drive (usually called C you will have a bunch of folders (such as "Windows" and "Program files").
Anything that is NOT in one of those folders will be "on the root of C:" or "in the root directory of C:".
For example:
C:\Program Files\Microsoft Word\Word.exe. - Here, Word.exe is NOT in the root of C:
C:\Myfile.doc. - Here, Myfile.doc *IS*.
Now, to make it more confusing, you can extend this to a foder... When you have folders nested inside folders, inside folders; you might say "Now 'Myfile2.doc' is in the root of the 'My Documents' folder.. That means it is in the folder, but not inside any of the folders that are also inside "My Documents".
Hope that helps to get your files into the right place!
What files were you being told to put in the root directory anyway? All the speed camera data files and the other POI files and the ogg voice files all would want to go inside the map folder on your One. |
