xtian Occasional Visitor
Posted: Mon Oct 01, 2007 4:18 pm Post subject: Cameras Not Showing Up In TomTom One V2 |
UPDATE
I removed a lot of POI's and now have my cameras back, I think the software update took more space.
Hopefully I may find help.
I have been using Pocket GPS cameras for over 3 years, so I am confident in updating my TomTom.
What has happened is I have a TOMTOM ONE V2 EUROPE.
I had the camera database on my TT and was working fine, did a TT update and updated the new Version TT 7.120
I then lost my voice warning for cameras, ok I thought I will try the data.chk file, didn't work.
I thought ok I will restore my original backup with the cameras and voice warnings. This did not work.
I have now a up to date TT ONE V2 Europe but the cameras do no show in the POI option on the device, even though I can see them on on my laptop in the europe map folder.
PLEASE HELP
Also this new TOMTOM HOME 2 is a pain as well and is not making it any easier.
Is the current camera database compatible with the latest TT Europe V2 - 7.120
P.s - just took the £19 subscription out... gutter ... |
Andy_P Pocket GPS Moderator
Posted: Mon Oct 01, 2007 7:14 pm Post subject: Re: Cameras Not Showing Up In TomTom One V2 |
xtian wrote: | UPDATE
So you're OK now? |
gardenshed Frequent Visitor
Posted: Mon Oct 01, 2007 7:22 pm Post subject: |
from what i can make from this, if i am correct is
1 you have updated to 7.12
2 you have the camera database
3 no sounds or cameras
try going through the camera poi's and select each one, ie preferences, warn when near poi, set distance and sound
the reason they need re-activating is when you upgraded to 7.12 the sd card is flashed automatically and therefore no record of any warnings, it does this to clear it for the navcore install |
Posted: Mon Oct 01, 2007 8:16 pm Post subject: Cameras back |
Got my cameras back, took some POI's off the list..
Got no voices for speed camera alerts the data chk file don't work with this version i think. |
Posted: Mon Oct 01, 2007 8:22 pm Post subject: Re: Cameras back |
xtian wrote: |
Got no voices for speed camera alerts the data chk file don't work with this version i think. | yes it does m8 ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Mon Oct 01, 2007 8:26 pm Post subject: Data chk file number |
data chk file number do i need?? |
Posted: Mon Oct 01, 2007 8:29 pm Post subject: Re: Data chk file number |
xtian wrote: | data chk file number do i need?? | if you got the updated navcore of tt site or home then you have the correct files, i would suggest re-installing and then re setting cams and downloading the voice files again |
Posted: Mon Oct 01, 2007 8:34 pm Post subject: |
There is no data.chk file for version 7 software (unless someone has been messing around to create it) - the data.chk method was dropped a while back in favour of using ogg audio files, you will find a comprehensive guide to this, including links to the ogg file download page Here - I appreciate the guide only states vs5 and 6 software, so it does need an update, this facelift is on my list of things to do - Mike |
Posted: Mon Oct 01, 2007 8:36 pm Post subject: voices |
are you meaning the gatso 30 etc voices |
Posted: Mon Oct 01, 2007 8:44 pm Post subject: |
ogg audio warnings correspond to each of the POI categories and do indeed produce sounds like "Warning Gatso ahead, speed limit is 30 miles per hour" - if this is what you want on your device forget all about data.chk as it simply will not work and follow the link I provided in my previous post, if you get stuck with the ogg file method let us know where it has gone wrong, but I can assure you this works with the version 7 software - Mike |
Posted: Mon Oct 01, 2007 9:59 pm Post subject: Voices are back |
Thanks for your help
all cameras and audio voices for speed limits are back.
cheers. |
