Pocket GPS World :: View topic - Mio 168 Strange problems
ajm600
PostPosted: Tue Sep 25, 2007 7:29 pm    Post subject: Mio 168 Strange problems Reply with quote
Hi everyone! I hope someone out there can help me. This is not the usual connector problem (which I have suffered from in the past).
There are 2 issues:
I have had my Mio 168 + TomTom 5 for a couple of years now. It has always been very slow in registering satellites, but now it is beyond a joke. It can take more than 15 minutes, and even after that it will drop out for 5 minutes at a time at irregular intervals.
If I set the display to “show GPS status”, it shows a quite healthy situation with seven or eight long bars, but it does not register my position and turn the bars blue until those many minutes have passed. Using the extension cable increases the bar length, but does not make any difference to the time taken to register. I can, in fact, monitor the “dropping out” when, after the Mio registers my position, the blue bars immediately fall to almost zero – then rise again.
I thought that in order to cure this, I perhaps needed to reinstall TT5 on the PDA, but when I try to do that, another problem arises. The PC tells me “USB device not recognised” and refuses to connect. I wanted to do a hard reset, but am afraid: a) I don’t know if it will make my GPS receiver any better, and b) I don’t know if I will be able to connect afterwards anyway because of the non-recognition issue.
Sorry to be so long-winded, but I have tried to describe the symptoms as accurately as possible. Can anyone help? Please. I love my Mio but it is driving me crazy at the mo.
dabut
PostPosted: Tue Sep 25, 2007 8:42 pm    Post subject: Reply with quote
hi
have you got gps settings on
other nmea/4800 baud rate/serial cable sp2
and are you sure your connector at bottom of pda is not faulty
ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6
ajm600
PostPosted: Tue Sep 25, 2007 9:46 pm    Post subject: Reply with quote
Thanks, but I have tried that before and it doesn't work. The unit has always worked fine on "TomTom Cable GPS". However, because you kindly took the time to reply, I tried NMEA again. Nada.
aj2052
PostPosted: Wed Sep 26, 2007 2:27 am    Post subject: Reply with quote
I have tried tomtom cable setting on my mio168 in the past and found the signal not reliable and found the NMEA setting to be reliable all of the time
ajm600
PostPosted: Wed Sep 26, 2007 5:07 pm    Post subject: Reply with quote
Well. Who would have thunk it! The NMEA setting really does work! I have used the TomTom Cable from the first, and never would have thought to use another setting. Anyway, NMEA does seem to be more stable and faster reacting. Thank you very much indeed.
Now all I have to sort out is the PC/USB connection. But that it less urgent now that my GPS functions again. The connector did go wrong about 12 months ago and was changed. Perhaps it has gone wonky again. Pity, I won't be able to update speed cameras.
Thank you once more for your splendid advice.
PostPosted: Wed Sep 26, 2007 5:19 pm    Post subject: Reply with quote
Use a card reader to install/ update the speed cameras on the device - Mike
aj2052
PostPosted: Thu Sep 27, 2007 1:30 am    Post subject: Reply with quote
Cant help you with pc/usb connection, I have used my Mio168 for over 2 years and never had a problem with connection, i use it for interfacing with Outlook for keeping Address book uptodate, I presume you have Activsync Installed which works very well.
ajm600
PostPosted: Thu Sep 27, 2007 12:40 pm    Post subject: Reply with quote
How exactly do I do this? I have TT5 on my Mio and do not know where to go on your site to get the download.
PostPosted: Thu Sep 27, 2007 1:16 pm    Post subject: Reply with quote
As you have TomTom 5 on the SD card will be a number of folders one of these folders is the Map folder it will be quite obvious from the folder name "Great_Britain" or "Western_Europe" etc. Into this folder you copy/ Paste the POI files, each POI category comprises of a bmp file (the icon image) and an ov2 file which contains the individual locations within that category.
To get the PocketGPSWorld Speed Camera database you need to be a subscribed member of the site This Thread explains the database and how it is obtained - Mike
22.094 (25 Sep 24)
