Pocket GPS World :: View topic - Advice on TomTom 520 Mount
istinson
PostPosted: Tue Sep 25, 2007 1:39 pm    Post subject: Advice on TomTom 520 Mount Reply with quote
Can anyone advise me on a good dashboard mount that hs easy to remove completely (no clues to thieves). I previously had a One which I attached magnetically using a Krusell Quickmount magnet & metal strip. Alas this won't stick well to the Go & it covers the speaker making John Cleese sound like a dalek.
I've seen pictures of the ? Brodit ones but they seem to need a huge unsitely plate wihch would cover my Vectra C's airvents.
Many thanks
Ian
Very Happy
PostPosted: Tue Sep 25, 2007 1:53 pm    Post subject: Reply with quote
How about using just the small square plate (that slips into the groove on the back of the TT) from the Brodit mount and fix that to your magnet thing?
istinson
PostPosted: Tue Sep 25, 2007 4:05 pm    Post subject: Reply with quote
Aha - is the Brodit clip steel hence magnetic ?? Question
Ian
PostPosted: Tue Sep 25, 2007 4:13 pm    Post subject: Reply with quote
No, its plastic.
I might have this wrong then.... I looked at the Krusell Quickmount on the web and thought the magnet itself went on the back of the unit, and that then clamped itself to a steel part of the dashboard.
Reading your post more carefully, you mention a steel strip. Does that go on the back of the satnav instead? If so, isn't the big magnet bit left on the dash? 'Cos you said you were looking for a solution where it leaves no clues...
Tell us what bit goes where and I'll have another think Smile
istinson
PostPosted: Tue Sep 25, 2007 4:32 pm    Post subject: Reply with quote
Thanks the (very strong) magnet itself is a circular rubber covered disc that is slightly larger than a 10 p piece that sticks to the dashboard. It comes with a small adhesive metal strip - I'd put 2 of these on my One V2 (where the mount would normally attach) and this attached the One very securely.
Because of the curve ot the 520 & also putting it over the speaker grill means that the small strips (I've tried 2 ) do not stick The stips are about 4cm x 2cm long. (BTW it is an excellent and almost invisible solution for mounting any mobile phone !!)
I suppose if the brodit base is flat the strips could be stuck to that Rolling Eyes
PostPosted: Tue Sep 25, 2007 4:44 pm    Post subject: Reply with quote
Right... got you.
If you don't mind having the magnet in view, maybe you wouldn't mind a Brodit "move clip", which is a flat wedge plate. Maybe not as elegant as the magnet, but much less objectionable than the normal vent-type mounts.
I've got one glued to my dash with the supplied sticky strips and it's been solid as a rock (and that ws with a heavy GO300!). I also used the spare plate to mount a dummy airfreshner for when I'm parked in a dodgy area, but don't tell anyone!!
Have a look at this page, which shows the Moveclip and another brand plate for the 720
http://www.dsldevelopments.com/brodit/moveclipsDSL.asp
Or there's a "mini moveclip" HERE. Must admit, I can't remember which one I've got.
22.055 (29 May 24)
