Pocket GPS World :: View topic - GPS V3.0 Available...
SpeedCam
PostPosted: Sun Mar 28, 2004 8:59 pm    Post subject: GPS V3.0 Available... Reply with quote
I'm not sure what the improvements are, but if you download the TomTom V3.01 Update, there is a GPS folder which contains an updated GPS V3 driver.
Copy the CAB file to your PPC and then double click on the file, it will install. It seems to work with TT V2 so it might fix the bluetooth problems.
Best of luck...
hegedusa
PostPosted: Sun Mar 28, 2004 10:26 pm    Post subject: Re: GPS V3.0 Available... Reply with quote
Best of luck...
Sorry to ask, but where is this folder?
PostPosted: Sun Mar 28, 2004 11:12 pm    Post subject: Reply with quote
Well spotted! I've installed it and it appears to suffer none of the COM Port locking debacle that 2.08 and 2.09 had Thumbs Up
I can now access Memory-Map and other GPS apps without having to mess around uninstalling TomTom~GPS.
For the benefit of others, download the TTN 3.01 update .zip file to a folder and launch the setup.exe. This unpacks the remainder of the files and folders one of which is a 'GPS' folder. In this are three .cab files, one ecah for ARM, SH3 and MIPS processors.
Copy the relevant cab file to your PPC. Uninstall the existing GPS driver, soft reset and then double tap the .cab file using file explorer on the PPC to launch the install, it will soft reset and auto delete the .cab file on installation.
MrT
PostPosted: Mon Mar 29, 2004 7:04 am    Post subject: No joy Reply with quote
I installed the 3.0 GPS after removing and resetting GPS 2.09 (never installed the wizard with BT update). I still get the greedy port syndrome, but uninstalling the TomTom~GPS, as before, allowed the port to be accessed by other apps without removing the TomTom 3 GPS.
PostPosted: Mon Mar 29, 2004 7:31 am    Post subject: Reply with quote
Hmm, we'll need to take a closer look at this. I had v2.07 previously and after uninstalling that and installing v3 I have not had the COM port issue.
MrT
PostPosted: Mon Mar 29, 2004 7:52 am    Post subject: Reply with quote
Another little new nasty.
If you start TT without the PDA BT turned on, it unchecks the "tick" in the GPS box for selecting the TT BT GPS unit and shows GPS disabled.
After turning the BT back on and even after restarting TT it remains unselected and disabled, so you have to reselect the TT BT GPS check in the GPS applet.
Previously once you re-enabled you PDA bluetooth it just resumed the GPS connection.
Reverting to GPS 2.0x does not resolve the problem so something else must have changed.
The setting in the registry that it is changing itself is:
HKLM\SOFTWARE\TomTom\GPS Engine\Enabled (=1 or 0)
kdee
PostPosted: Mon Mar 29, 2004 5:25 pm    Post subject: Re: No joy Reply with quote
Same here
PostPosted: Mon Mar 29, 2004 5:30 pm    Post subject: Reply with quote
Did you remove both TomTomGPS and TomTom~GPS entries before installing v3.0?
kdee
PostPosted: Tue Mar 30, 2004 5:14 pm    Post subject: Reply with quote
I only had the TomTom ~ GPS entry, but I removed that one
alix776
PostPosted: Wed Mar 31, 2004 4:25 pm    Post subject: Reply with quote
i tried the update and tt3 kept freeze after 2 or 3 miles
device Lumia 950 xl
alix776
PostPosted: Wed Mar 31, 2004 4:43 pm    Post subject: Reply with quote
just tried that darren hope itll work
device Lumia 950 xl
Taz
PostPosted: Wed Mar 31, 2004 9:52 pm    Post subject: Re: GPS V3.0 Available... Reply with quote
Can anyone provide a link please ( Embarassed Newbie Embarassed )
PostPosted: Wed Mar 31, 2004 9:58 pm    Post subject: Reply with quote
Download it here.
Taz
PostPosted: Wed Mar 31, 2004 10:09 pm    Post subject: Reply with quote
Many thanks
alix776
PostPosted: Thu Apr 01, 2004 4:08 pm    Post subject: Reply with quote
unfortunatly the fix didnt work last night so i need to try something different anyone got any ideas it works fine with the cf receiver bbut use bt and it freezes after a couple of miles
device Lumia 950 xl
22.094 (25 Sep 24)
