SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Sun Mar 28, 2004 8:59 pm Post subject: GPS V3.0 Available... |
I'm not sure what the improvements are, but if you download the TomTom V3.01 Update, there is a GPS folder which contains an updated GPS V3 driver.
Copy the CAB file to your PPC and then double click on the file, it will install. It seems to work with TT V2 so it might fix the bluetooth problems.
Best of luck... |
hegedusa Occasional Visitor
Posted: Sun Mar 28, 2004 10:26 pm Post subject: Re: GPS V3.0 Available... |
SpeedCam wrote: | I'm not sure what the improvements are, but if you download the TomTom V3.01 Update, there is a GPS folder which contains an updated GPS V3 driver.
Best of luck... |
Sorry to ask, but where is this folder? |
Darren Frequent Visitor
Posted: Sun Mar 28, 2004 11:12 pm Post subject: |
Well spotted! I've installed it and it appears to suffer none of the COM Port locking debacle that 2.08 and 2.09 had
I can now access Memory-Map and other GPS apps without having to mess around uninstalling TomTom~GPS.
For the benefit of others, download the TTN 3.01 update .zip file to a folder and launch the setup.exe. This unpacks the remainder of the files and folders one of which is a 'GPS' folder. In this are three .cab files, one ecah for ARM, SH3 and MIPS processors.
Copy the relevant cab file to your PPC. Uninstall the existing GPS driver, soft reset and then double tap the .cab file using file explorer on the PPC to launch the install, it will soft reset and auto delete the .cab file on installation. _________________ Darren Griffin |
MrT Frequent Visitor
Posted: Mon Mar 29, 2004 7:04 am Post subject: No joy |
I installed the 3.0 GPS after removing and resetting GPS 2.09 (never installed the wizard with BT update). I still get the greedy port syndrome, but uninstalling the TomTom~GPS, as before, allowed the port to be accessed by other apps without removing the TomTom 3 GPS. |
Posted: Mon Mar 29, 2004 7:31 am Post subject: |
Hmm, we'll need to take a closer look at this. I had v2.07 previously and after uninstalling that and installing v3 I have not had the COM port issue. _________________ Darren Griffin |
Posted: Mon Mar 29, 2004 7:52 am Post subject: |
Another little new nasty.
If you start TT without the PDA BT turned on, it unchecks the "tick" in the GPS box for selecting the TT BT GPS unit and shows GPS disabled.
After turning the BT back on and even after restarting TT it remains unselected and disabled, so you have to reselect the TT BT GPS check in the GPS applet.
Previously once you re-enabled you PDA bluetooth it just resumed the GPS connection.
Reverting to GPS 2.0x does not resolve the problem so something else must have changed.
The setting in the registry that it is changing itself is:
HKLM\SOFTWARE\TomTom\GPS Engine\Enabled (=1 or 0) |
kdee Occasional Visitor
Posted: Mon Mar 29, 2004 5:25 pm Post subject: Re: No joy |
MrT wrote: | I installed the 3.0 GPS after removing and resetting GPS 2.09 (never installed the wizard with BT update). I still get the greedy port syndrome, but uninstalling the TomTom~GPS, as before, allowed the port to be accessed by other apps without removing the TomTom 3 GPS. |
Same here |
Posted: Mon Mar 29, 2004 5:30 pm Post subject: |
Did you remove both TomTomGPS and TomTom~GPS entries before installing v3.0? _________________ Darren Griffin |
Posted: Tue Mar 30, 2004 5:14 pm Post subject: |
I only had the TomTom ~ GPS entry, but I removed that one |
alix776 Pocket GPS Moderator
Posted: Wed Mar 31, 2004 4:25 pm Post subject: |
i tried the update and tt3 kept freeze after 2 or 3 miles _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed Mar 31, 2004 4:43 pm Post subject: |
just tried that darren hope itll work _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Taz Regular Visitor
Posted: Wed Mar 31, 2004 9:52 pm Post subject: Re: GPS V3.0 Available... |
Can anyone provide a link please ( Newbie )
Thanks |
Posted: Wed Mar 31, 2004 9:58 pm Post subject: |
Download it here. _________________ Darren Griffin |
Taz Regular Visitor
Posted: Wed Mar 31, 2004 10:09 pm Post subject: |
Many thanks |
Posted: Thu Apr 01, 2004 4:08 pm Post subject: |
unfortunatly the fix didnt work last night so i need to try something different anyone got any ideas it works fine with the cf receiver bbut use bt and it freezes after a couple of miles _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
