Pocket GPS World :: View topic - NUVI 660 leaves mount on bump
RobertV
PostPosted: Tue Sep 18, 2007 6:07 pm    Post subject: NUVI 660 leaves mount on bump Reply with quote
Has anyone else had the problem of the NUVI 660 coming off the mount when hitting a bump in the road? Fortunately mine ended up in the door pocket so it appears not to be damaged. On inspection I notice that it does not latch in very tightly. Anyone have any ideas how to overcome this problem?
Garmin NUVI 660 with 2010 maps, Navman 550, Garmin Etrex Vista, Garmin 775
GJF
PostPosted: Wed Sep 19, 2007 10:43 am    Post subject: Reply with quote
When fitting the Nuvi to the mount, there should be a distinct click where it locks in with the spring catch, is this happening with your mount?
Maybe the mount is faulty.
I have had a lot of trouble with the mount falling off the glass and have since changed to a Brodit mount, but not the Nuvi coming unattached from the mount.
TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver
tigre64
PostPosted: Thu Sep 20, 2007 10:46 am    Post subject: Reply with quote
drive slower over the bumps Laughing Wink
philpugh
PostPosted: Thu Sep 20, 2007 1:12 pm    Post subject: Reply with quote
Same as GJF. Should be a very positive lock on the mount. Had the windscreen mount fall off a couple of times - with 660 in it. Both times no damage to unit - and it didn't leave the mount. Since got a Brodit mount for the center console - much nicer mount - blends in with car so no need to remove mount when leaving vehicle. Check how you are placing the unit in the holder. I find locating the lower bit first then 'pivot' it up to complete the mount - it gives a very satisfying click. If you aren't getting this - then back to the retailer for a replacement mount.
Phil
22.094 (25 Sep 24)
