RobertV Regular Visitor
Joined: Jan 08, 2006 Posts: 74 Location: Newcastle Upon Tyne, UK
Posted: Tue Sep 18, 2007 6:07 pm Post subject: NUVI 660 leaves mount on bump |
Has anyone else had the problem of the NUVI 660 coming off the mount when hitting a bump in the road? Fortunately mine ended up in the door pocket so it appears not to be damaged. On inspection I notice that it does not latch in very tightly. Anyone have any ideas how to overcome this problem? _________________ Garmin NUVI 660 with 2010 maps, Navman 550, Garmin Etrex Vista, Garmin 775 |
GJF Frequent Visitor
Posted: Wed Sep 19, 2007 10:43 am Post subject: |
When fitting the Nuvi to the mount, there should be a distinct click where it locks in with the spring catch, is this happening with your mount?
Maybe the mount is faulty.
I have had a lot of trouble with the mount falling off the glass and have since changed to a Brodit mount, but not the Nuvi coming unattached from the mount. _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
tigre64 Occasional Visitor
Posted: Thu Sep 20, 2007 10:46 am Post subject: |
drive slower over the bumps |
philpugh Lifetime Member
Posted: Thu Sep 20, 2007 1:12 pm Post subject: |
Same as GJF. Should be a very positive lock on the mount. Had the windscreen mount fall off a couple of times - with 660 in it. Both times no damage to unit - and it didn't leave the mount. Since got a Brodit mount for the center console - much nicer mount - blends in with car so no need to remove mount when leaving vehicle. Check how you are placing the unit in the holder. I find locating the lower bit first then 'pivot' it up to complete the mount - it gives a very satisfying click. If you aren't getting this - then back to the retailer for a replacement mount. _________________ Phil |
