junior78 Occasional Visitor
Posted: Tue Sep 18, 2007 12:59 pm Post subject: Help with TomTom6 + Solar Bluetooth GPS receiver |
I have got a XDA exec with Tomtom6 and a Solar Bluetooth GPS receiver...I am able to pair the device with my PDA and am also able to configure and define incoming and outgoing ports...COM 8 for incoming and COM 4 for outgoing....when I try and go to my tomtom software the only option which I get is to select the GPS type, in order to configure the device....and after selecting it keeps connecting to GPS device and nothing happens....I have even tried with Incoming (COM4) and Outgoing (COM8) and even with COM0 settings for COM ports within XDA, but to my bad luck I am not able to connect to the GPS device....can someone kindly help me with the above please
Thanks |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Tue Sep 18, 2007 3:03 pm Post subject: Re: Help with TomTom6 + Solar Bluetooth GPS receiver |
When you say junior78 wrote: | when I try and go to my tomtom software the only option which I get is to select the GPS type, in order to configure the device....and after selecting it ... | What type are you selecting? Have you tried selecting a different type?
I don't have an XDA, so I can't help directly, but a few others do use them, so I'm sure someone will be able to help out soon! _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Tue Sep 18, 2007 3:43 pm Post subject: |
thanks for the msg...I am using a BT Solar Bluetooth GPS receiver...and when I try to configure the same using my Tomtom interface, the only option I get is to select the GPS type and once I select it shows me the next screeen saying connecting to GPS device and thereafter nothing happens....while pairing I use the 0000 passkey with the GPS so i select the same GPS receiver which shows a key with 0000, since its a non interactive device i thought this would work....hope I am able to convey the problem...kindly help...thanks |
Posted: Tue Sep 18, 2007 4:37 pm Post subject: |
Have a read through This Thread, the screen shots and port numbers mentioned will be correct for your device as I created the screen shots using an Exec. You only need the Outgoing port and don't forget the serial port profile check box. If following the guide fails please let us know at which point it falls over - Mike |
Posted: Tue Sep 18, 2007 4:57 pm Post subject: |
Before we go any further, can I check that you have followed this thread? Which, in turn, points to the instructions in this thread.
I'd hate for us to waste time re-inventing the wheel! _________________ Jock
Posted: Tue Sep 18, 2007 5:00 pm Post subject: |
Mike,
SNAP!! _________________ Jock
Posted: Tue Sep 18, 2007 6:30 pm Post subject: |
Hi there,
appologies for creating a thread....but i was desperate so honestly didn;t go thru this....thanks a lot to both of you....I shall try this and hopefully it should work...thanks BGF and Mike...cheers |
Posted: Tue Sep 18, 2007 6:42 pm Post subject: |
Please don't apologise for posting on the forum, you need the information to get the device working - sometimes searching for information can offer results other times a question can be far faster in getting you the information you need, let us know how you get on configuring the device - Mike
BGF - Snap is a little too easy, I far prefer the game of Kalooki when it comes around to card games - Mike |
Posted: Fri Sep 21, 2007 11:55 am Post subject: |
hey hey...i have been able to connect my XDA exec with GPS and its just so nice....and I would like to take this opportunity to thank you both for all ur replies and help....smiles, junior |
