FrequentFlyer Lifetime Member
Posted: Sun Sep 16, 2007 1:43 pm Post subject: 'Missing' POI's ? |
I recently upgraded my TT6 with the latest maps...Uk + Major European Roads(V.675.1409). However, I've just realised that TT's standard list of POI's only applies to the UK only...I assume that is correct ? I was looking to plan a route from Nice airport....which I couldn't find in the POI list of airports. |
Posted: Sun Sep 16, 2007 2:18 pm Post subject: |
Just plan it using depart from Lat / Long and use N43.66533 E7.20727 these should be close enough to the airport main entrance road, use Google Earth to get co-ords like this, then add it in as a custom POI category, you can update the actual position of the airport POI when you get there - Mike |
Posted: Mon Sep 17, 2007 3:01 pm Post subject: |
Thanks...how easy/difficult would it be to transfer over the POI's from the TT5 French/Spanish maps, to the TT6 'Major Roads of Europe'. It's annoying because our hotels are all shown in the TT5 version, but nothing of course on TT6. |
Posted: Mon Sep 17, 2007 5:01 pm Post subject: |
Make sure everything is backed up then try it, the inbuilt POI are stored in a single file named POI.dat I am not too sure if the POI files will work too well though as they may return a route error if they are not on or close to a major road, the other problem in doing this is you will loose the UK inbuilt POI as you can only have a single POI.dat file at any one time, the usual method of concatenating the POI files will not work with the in built POI without a lot of messing around - Mike |
Posted: Tue Sep 18, 2007 8:52 am Post subject: |
Thanks...too much trouble, I think I'll reinstall TT5, or have a look at your POI download site to see what's available. Disappointing though...I wonder how many others don't realise that with the 'Major Roads of Europe' part you don't get any POI's ? |
