Pocket GPS World :: View topic - Custom Cursors made easyand different and FREE
bunnyman69
PostPosted: Mon Sep 17, 2007 9:13 pm    Post subject: Custom Cursors made easyand different and FREE Reply with quote
I think have stumbled across a way to make these custom cursors so easy, well they are working for me anyway.
But i'm doing things different....as normal
1)saved as a gif (will make file smaller than bitmap even default blue arrow comes down to 2kb from original 19kb)
2)can save upto 128 X 128 pixels
3)no red at all shown around saved image, what you see is what you get!
Firstly i download an app called paint.net from
http://www.getpaint.net/index.html
Takes up less than 10mb when istalled too according to installed location, control panel only shows it as 4.5 mb.
I didn't have to install net framework on my pc as i already had
Once installed i opened a pic within paint.net (was a 3 megapixel jpeg taken of my van)
rotated image (image .. rotate 90)
I then selected rectangle select from the small tool box selection on left (top left) and selected the best looking square around the van. selected 8th icon across on toolbar (crop to selection under layers).
Then image... resized 128 X 128 (de-selected the maintain aspect ratio due to the above rectangle select not being a perfect square).
Image then goes too small to work on so either use ctrl and + together to zoom in............likewise " - minus to zoom out" or can be also done by view...zoom in/out
Now select the erazer tool 6th down on the right in the toolbox on left. Make the brush size what you feel comfortable with, i started off around 15
and then went smaller towards the end. What you are doing now is rubbing out all the surrounding area to leave just your car or homer simpson so you leave a grey and white patch work efect behind. If you can get a good contrasting background behind ya object select the magic wand (4th down in left in toolbox) and adjust tolerence to how sensitive it is, then simply cut the area out.
I finished off using the colour picker to get colour of tyres and used the paintbrush with a very small brush width to get the outline nice and sharp
when finished select file..save as and make sure to select gif
the next page appears and i just selected default ie, 128....7.....multply alpha channel (cus i have not got a clue what they are ha ha)
Load the gif into /art/cars on the X20 unit
Let me know how you get on folks as this was a pure fluke. i was reading about 24bit bmp's 80X80 and 255,000,000,000 wtf.
Oh yeah if you like your image simpley load it back into paint.net and select image ...resize and go smaller now if need be (80X80 maybe)
My gif looks great, can read the sign writing on the back and file was about 4kb.
The whole process will take less than a minute once you get the hang of it
I just wish they worked in 2D, cus this is my preference Sad
PostPosted: Tue Sep 18, 2007 8:44 am    Post subject: Reply with quote
interesting. so i guess you can either use transparency in gif's or use 'red' as the transparent colour in a bitmap.
wonder if they added support for alpha channels in png's?!
22.064 (26 Jun 24)
