JF_1976 Occasional Visitor
Posted: Sun Sep 16, 2007 12:37 pm Post subject: EUR vs UK speed camera spoken alerts |
All,
I did do a forum search on the above (but had over 22,000 returned results..). Hopefully this is a quick one to answer.
I have a GO 510, and d/l the speed camera DB (speed zoned version) and the appropriate warning .ogg files. All was working perfectly.
I recently purchased a new Western Europe map on SD (direct from tomtom) and so have downloaded the equivalent european speed camera DB.
2 questions:
1) Do I need to re-install the UK speed camera DB, or are they included in the EUR DB?
2) If I do need 2 seperate DBs (UK & EUR) does it follow that I simply have to copy and rename the spoken alerts (.ogg files)
i.e copy pocketgps_uk_gatso_30.ogg
rename to pocketgps_eur_gatso_30.ogg
Thanks in advance for the help. |
Posted: Sun Sep 16, 2007 12:48 pm Post subject: |
You will need to install both the Euro file set AND the UK file set to the map folder as each download is different.
As for a set of ogg files that corespond to the Euro cameras these need to be in KPH I have sent you a file set that are correctly named, so check your e-mail - Mike |
Posted: Sun Sep 16, 2007 1:48 pm Post subject: |
mikealder wrote: | ...... I have sent you a file set that are correctly named, so check your e-mail - Mike |
PERFECT! Wow, thanks very much Mike. Downloaded and installed - works a charm. |
