Pocket GPS World :: View topic - Static Navigation Effect on GPS Software Question
neoshi
PostPosted: Fri Sep 14, 2007 6:04 pm    Post subject: Static Navigation Effect on GPS Software Question Reply with quote
Hi all,
I've been wondering about the MTK static navigation issue though. Does it have any substantial effect on GPS software (i.e. Route 66) in that it will cause your software to assume you are still moving/somewhere else and therefore affect your turn-by-turn directions? The reason I ask is that while I see the tracks that MTK chipsets have been drawing under the numerous logs posted, I have yet to see a demonstration of whether or not they could potentially cause someone to go around in circles while walking around in a city with tall buildings (i.e. namely Tokyo or New York) or have a wrong fix (i.e. assume I am three blocks ahead and cause me to turn early even though the street name doesn't match).
Your answers would be greatly appreciated. Thank you.
neoshi
PostPosted: Sun Sep 16, 2007 5:24 am    Post subject: Reply with quote
perhaps this belongs in the advanced lounge? doesn't seem to gather a response here. Crying or Very sad
Skippy
PostPosted: Sun Sep 16, 2007 8:56 am    Post subject: Reply with quote
Hi and Welcome
I don't have specific experience with the MTK GPS but my experience of SiRF chipsets is that you need to switch static navigation off when walking.
In a car, you move fast and decisively in one direction so static navigation works. But walking you tend to move in fairly random directions at a slow speed so with static navigation your position will only update every 20-30 meters which makes the GPS pretty much useless.
In "urban canyons" where you don't have a good reception is quite a different story. The problem here is that your position can be 20 to 50 meters (or more) adrift from reality. You have to be very aware of what sort of fix you have and figure out when your unit is confused and when it's giving good information.
Bottom line recommendation: SN OFF for walking, ON for driving. I just leave it Off all the time though and the occasional jittering of position doesn't bother me...
Gone fishing!
neoshi
PostPosted: Sun Sep 16, 2007 10:03 am    Post subject: Reply with quote
Thanks Skippy!
The problem is I've only had experience with all-in-one solutions (i.e. Garmin Nuvi) where they pretty accurately depict my positions and give a decent amount of time and warning before you actually need to turn.
I'm worried that with SN on, the GPS will think I'm 50m ahead (especially if I'm stopped at a traffic light) and will proceed to depict that I am moving and approaching an intersection where I need to turn, make decision, etc. I suppose I will have to go ahead and try it for myself.
I don't plan on using the GPS much for walking and even if I do, I don't have software on my PDA to actually depict it without data plan requirements (any suggestions here?) So, as long as I stick to the streets, I think an MTK chipset will be just fine.
I've been considering SiRFIII receivers but the most recent developments seem to be all MTK receivers. But I'll have to think about it a little while longer to decide on a decent SiRFIII BT receiver if I decide to skip the MTKs. In addition, I don't know of any SiRFIIIs that have an on-the-fly method of switching SN off. As far as I know, I have to switch it off via commands through a computer and that doesn't make a car to foot transition easy.
philpugh
PostPosted: Sun Sep 16, 2007 10:04 pm    Post subject: Reply with quote
In my opinion it's not worth worrying about turning SN on when in a car. So what if you get a small amount of position wandering - it's not going to affect things. PND for cars already 'manipulate' the calculated GPS position to place you on the road in any case
Phil
robertn
PostPosted: Sun Sep 16, 2007 11:26 pm    Post subject: Reply with quote
These devices are tools that aid your navigation. Only a fool would rely solely on GPS - as more than a few marineers have found out in the past.
we should all take a lesson from our salty cousins......
neoshi
PostPosted: Mon Sep 17, 2007 1:11 am    Post subject: Reply with quote
The problem here is that SN is ALWAYS ON in MTK chipsets. I believe THAT, in itself, creates potential issues with navigation. But of course, there is always some sort of "correction" done by the software counterpart, so I believe, from what I've heard thus far, is that despite SN having wandering issues in MTK chipsets, it will not present itself as a problem when coupled with navigation software.
Charting my walks is only an issue when I go hiking, where there are no streets, but landmarks will always be my key in such a case.
Thanks guys.
philpugh
PostPosted: Mon Sep 17, 2007 9:46 am    Post subject: Reply with quote
Thanks guys.
It's not the chipset that has the "wandering problems", they are caused by inherent inaccuraccies in the system - changes in atmospheric pressures and temp, poor sat geometery, local conditions etc all create slight errors.
I've not looked at the MTK chipsets, but if you really can't turn the SN off then this would seem to be a little short sighted.
Phil
neoshi
PostPosted: Mon Sep 17, 2007 8:36 pm    Post subject: Reply with quote
Shortsighted indeed. Most of the recent MTK-based receivers are coming out of Taiwan and Hong Kong though, where (from personal experience) we don't walk much. That probably explains why there has been no need for providing an "off button" for SN.
I think I'll just give the MTK receivers a try anyhow. SiRFIII receivers with equivalent capabilities seem to cost $30-50 more.
Skippy
PostPosted: Mon Sep 17, 2007 9:34 pm    Post subject: Reply with quote
I've not used one either, but "Static Navigation" as we know it on SiRF chipsets may be implemented completely differently on other GPS units - I don't think you can necessarily compare the two.
Gone fishing!
neoshi
PostPosted: Tue Sep 18, 2007 12:24 am    Post subject: Reply with quote
Yeah. Luckily, I don't think it's as big of a problem as multipath errors. Sucks when you're on Market Street and the GPS thinks you're on Broadway... Mad
