Pocket GPS World :: View topic - Myguide 3100 Running IGO Software
Goto page Previous  1, 2, 3, 4, 5  Next
gIzzE
PostPosted: Mon Sep 10, 2007 11:32 pm    Post subject: Reply with quote
So how do you run I-Go from it??
I have been using I-Go on my TyTN and love it, this would be ideal for £90 if I can transfer my I-Go card and get it running fully.
I know it looks pretty much the same but it seems the maps are old from reading the threads.
doughy
PostPosted: Tue Sep 11, 2007 2:30 pm    Post subject: Reply with quote
Yes im still wanting to know how to get igo running on the myguide.
norris26
PostPosted: Tue Sep 11, 2007 7:15 pm    Post subject: Reply with quote
i edited the addon txt file to enable the extra icons.
from there i can run the I-GO software from the sd card within windows using windows explorer but as i have already said the screen orientation is the wrong way round.
Navigate = "", "\\Flash Disk\\myguide\\myguide.exe"
Explorer = "", "\\Windows\\Explorer.exe"
Multimedia = "", "\\Flash Disk\\Xmovie\\xmovie""
gIzzE
PostPosted: Tue Sep 11, 2007 11:26 pm    Post subject: Reply with quote
There is an option somewhere in I-Go to rotate the screen, so you should be able to get it looking right.
Can you get the unit to boot straight into windows?? I put i-go in my start up folder so it booted straight away on my TyTN.
gIzzE
PostPosted: Tue Sep 11, 2007 11:28 pm    Post subject: Reply with quote
In fact can you edit the Navigation button to load I-Go instead??
Navigate = "", "\\Windows\\program files\\igo\\igo.exe"
Or where ever it is located??
norris26
PostPosted: Wed Sep 12, 2007 12:48 am    Post subject: Reply with quote
With the screen rotated i cant see what all the functions are so its hard to find the option to rotate the screen.
crossfordkid
PostPosted: Wed Sep 12, 2007 8:02 am    Post subject: Reply with quote
Hi norris26,
I had the same problem with the igo software on myguide 3100. You need to change the sys.txt file to have the following in it. Best bet is to create a copy of the existing one, delete the information and add the following.
Cheers,
Paul.
[device]
type="CARPOINTA1000"
[debug]
earth=0
slowsim=1
loop_sim=1
[interface]
landscape=1
show_zoombar=1
norris26
PostPosted: Wed Sep 12, 2007 2:36 pm    Post subject: Reply with quote
Thanks to everyone for all their help. I deleted all the myguide stuff of the satnav and replaced it with the Igo software. It was then just a matter of editing all the text files with the correct paths to run it and look for the maps on the sd card.
crossfordkid
PostPosted: Wed Sep 12, 2007 5:32 pm    Post subject: Reply with quote
Anybody managed to get Tomtom running on their Myguide 3100 ? Is so what version ?
Cheers.
abharsair
PostPosted: Mon Sep 17, 2007 9:26 pm    Post subject: Reply with quote
Can anyone help with actually getting activesync/windows to recognise my 3100? the support on the official website never gets back to my emails Sad
abharsair
PostPosted: Wed Sep 19, 2007 11:23 am    Post subject: Reply with quote
I've had a response to my email to suport
if the active sync (you need the new versioin from the internet active sync 4.5) is not working properly, it is much better that you read your SD Card via a Card Reader, you just need to read your SD-Card you dont need the device.
About a new update or an upgrade - sorry, there are none of them avaiable at the moment.
Kind regards
MyGuide-Service
c/o EZI GmbH
Kreuzgasse 42
D - 35708 Haiger
Tel: 01805 75 70 70 / 14Cent/Min
Fax: 01805 11 03 03 / 14Cent/Min
Mail: myguide-service@ezi.de
Pretty crap really Sad
gIzzE
PostPosted: Wed Sep 19, 2007 1:56 pm    Post subject: Reply with quote
What are you wanting to do with active sync??
abharsair
PostPosted: Thu Sep 20, 2007 10:52 am    Post subject: Reply with quote
actually connect my device would be a start ;)
then when that is working possibly load the igo software etc
Techdojo
PostPosted: Fri Nov 02, 2007 3:24 pm    Post subject: Reply with quote
I just purchased one of these from eBuyer and I've read through all the posts (several times), I've edited the file addons.txt on the SD card and the file IGOPATH.txt in the Flash Drive folder but whenever I turn the machine on (or even do a reset) all I get is the same two buttons "Navigate" and "Settings" on the front screen.
Note : I have had the unit plugged in to my PC when I do this...
Am I doing something wrong - or can someone give me a hint please?
Jon...
FokkerCharlie
PostPosted: Mon Nov 05, 2007 5:43 pm    Post subject: Reply with quote
Hello!
All this talk of running the Igo software on the MyGuide 3100- I take it that the purpose of this is to make use of map updates?
Also, where does one get the igo software in the first place?
FC
Page 4 of 5
22.063 (19 Jun 24)
