Pocket GPS World :: View topic - MASPware on a Aytobe ?
iepick
PostPosted: Thu Sep 06, 2007 2:21 pm    Post subject: MASPware on a Aytobe ? Reply with quote
Hi, being a newbie on satnav, bought an aytobe last week & managed to convert to TomTom . Noticed the below & wondered if it is possible to run this on an aytobe ?
h**p://mzezom.blogspot.com/2007/09/maspware-gpsmeter-professional-edition.html
MASPware GPSmeter Professional Edition v4.4
Do you still use your GPS device for navigating only?
Turn your Pocket PC into a high precision metering machine using your GPS receiver! With MASPware GPSmeter you can measure short and long distances (beeline or routelength), altitude differences, timespans, average values and min-max-values using an internal or external GPS receiver.
Whether measuring you golf drives, watch your running- or biking sessions, the route length to you work or whatever. Everythings no problem!
Precision depends on the GPS receiver you use. MASPware GPSmeter improves accuracy by calculating averages of position datasets. Furthermore, MASPware GPSmeter uses a High-Precision-Algorithm to evaluate precision values of the GPS receiver (Dilution of precision values).
So MASPware GPSmeter only uses high precision dataset values. Additionaly, you can use expert precision settings, to enforce needed precision.
Regards
22.055 (29 May 24)
