ianbar Occasional Visitor
Posted: Thu Mar 25, 2004 4:18 pm Post subject: TomTom Bluetooth GPS cradle |
Looking at the descriptions and illustrations on the TT website, it appears that the TT BT GPS receiver no longer includes the charging/docking cradle. Has anybody else spotted this, or is it just my imagination? |
Darren Frequent Visitor
Posted: Thu Mar 25, 2004 5:33 pm Post subject: |
No, you are quite correct. TomTom no onger supply the cradle. They ere of the opinion that it was this that was the casue of so many failures which is contrary to our findings. Anyway the end result is no more cradle which is a shame as for me it was the major reason I favoured that unit. _________________ Darren Griffin |
bjornh Occasional Visitor
Joined: Feb 03, 2004 Posts: 28 Location: Sweden, Visby
Posted: Thu Mar 25, 2004 5:59 pm Post subject: |
Does anyone know if it is the same TomTom GPS supply without the cradle or if it's an updated model?
//Björn H |
AlanW Occasional Visitor
Joined: Mar 21, 2004 Posts: 25 Location: Farnham, Surrey, UK
Posted: Thu Mar 25, 2004 7:14 pm Post subject: |
Darren wrote: | No, you are quite correct. TomTom no onger supply the cradle. They ere of the opinion that it was this that was the casue of so many failures which is contrary to our findings. Anyway the end result is no more cradle which is a shame as for me it was the major reason I favoured that unit. |
As a GPS newbie, I'm a little confused. Is this docking cradle solely for use with the GPS BT receiver, or are we talking about the cradle for the ppc? If it's for the GPS BT receiver, how does it get charged without the cradle? - Is there a separate mains charger? Does this mean that you can't charge the GPS BT receiver from the car?
Alan _________________ Time flies like a bird. Fruit flies like a banana |
Posted: Thu Mar 25, 2004 7:29 pm Post subject: |
The TomTom BT GPS was unique in having a cradle accessory which allowed semi-permanent in-car mounting and charging at the same time. It had two sockets so you could use either a cigar lighter cable or alternatively a 12v cable that could be hard wired directly into the car's electrics.
The BT unit itself also has its own charge jack into which you plug the supplied cigar charger cable so the cradle is not required and indeed as it is no longer supplied or available it needs it!
Early units failed rather too often, our experience (I think we had three out of four fail) suggested it was when being charged via the jack on the unit itself that it failed but TomTom appear to think it was the cradle that was the cause hence it's ommission from current packages. _________________ Darren Griffin |
Posted: Thu Mar 25, 2004 7:37 pm Post subject: |
Darren,
Thanks for the explanation. :D
Posted: Thu Mar 25, 2004 8:35 pm Post subject: |
Darren,
Thanks for the confirmation. Your comments on the (mis)diagnosis of the failure mechanism is a bit worrying. Do you know if the TomTom BT receiver reliability is OK now? It looks an attractive price when bundled with the TT3 software (about £200), but not if it is going to fail. |
Posted: Thu Mar 25, 2004 8:41 pm Post subject: |
I am glad to say that I have not haerd of failures for some time now so it is to be hoped that the problem has been resolved. To their credit there was never a problem getting the unit replaced when it failed, certainly mine has been going strong for 6 months or so since it was replaced. _________________ Darren Griffin |
Posted: Fri Mar 26, 2004 3:08 pm Post subject: |
Quote: | Does anyone know if it is the same old TomTom GPS (firmware 2.2 without EGNOS support ) supply without the cradle or if it's an updated model? |
Anyone?  |
Posted: Fri Mar 26, 2004 3:47 pm Post subject: |
Bjorn, i thought I had answered this but can't see my post! Anyway, the latest unit we have received from TomTom has identical firmware to earlier models. _________________ Darren Griffin |
Posted: Fri Mar 26, 2004 6:23 pm Post subject: |
Too bad!
I think I will buy Fortuna Clip-On instead.
I will primary use it in my camper when driving on holiday but also when walking in the city and forest.
Any comment on the choice of GPS?
//Björn H |
Posted: Fri Mar 26, 2004 6:47 pm Post subject: |
Nothing wrong with the Fortuna Clip-On although a V2 was shown at CeBIT which lackes the 'hump' of the first model and is consequently a little lower as well as running newer firmware.
My BT GPS of choice is the Royaltek RBT3000 Datalogger. The datalogger functionality is great and allows you to download and save log files from its internal memory store.
Just imagine replaying a walk or journey once home from your holidays! The datalogger replay software mimics a real GPS unit so you can sit at home and play the log file back through any GPS enabled software.
The downside is it is larger than most BT units and lacks a lanyard hole so may not be ideal for hiking etc. _________________ Darren Griffin |
Posted: Fri Mar 26, 2004 8:29 pm Post subject: |
I have seen that Clip-On v2 is on the way out.
Does v2 have ST/XT switch too. It's not on the picture on:
http://cebit.textamerica.com/?r=543786
The ST/XT function is the main thing for my choice, two GPS in one!
The Royaltec is not available in Sweden..
//Björn H |
thax1 Occasional Visitor
Posted: Sun Mar 28, 2004 12:58 pm Post subject: Wiring into Vectra |
Talking of the Tomtom BT GPS cradle, I spent yesterday afternoon wiring it into a new Vectra.
I'd decided on the rear parcel shelf as a location, but had never got around to finding a easy point to get 12v.
Following the recommendations of others on this forum, I checked the boot light. Sure enough, +12V between the red wire and the car metalwork.
Checked that this was still +12 when the bootlight was off, still OK.
Then after wiring it all in, checked the voltage to find it now swinging between 0.5v and 2v
It appears that after 5 mins of (simulating) the boot closure, the voltage is allowed to drop. Haven't a clue why, although this coincides with the disabling of the external boot release button (which is by design).
Pressing the button to enable the boot release reinstates +10v, and this rises to 12v once the boot is actually opened. Baffling.
In the end I got a solid +12v from the fuse box in the boot. Stays live at all times.
Should I be concerned that its more like +14v when the engine is running? |
Lost1 Regular Visitor
Joined: Jan 30, 2004 Posts: 68 Location: Merseyside UK
Posted: Sun Mar 28, 2004 8:12 pm Post subject: |
Apart from the functionality of being able to transfer my TTN2 BT kit between any vehicle I am using, the other major thing that swung my wallet was the fantastic set of fixings that came with the package.
I could probably fasten it to an iceberg with one of the many attachments in the kit. The package resembled a Swiss Army Knife and I was confident that what ever my needs there would be a combination in the pack even for charging via the mains at home or abroad.
If TomTom are starting to drop various bits of kit I think that this is a bad move. |
