Pocket GPS World :: View topic - Got lost (again) last night - is this right solution for me!
Goto page Previous  1, 2
PostPosted: Fri Mar 26, 2004 7:00 pm    Post subject: Reply with quote
HP 4150
Active Mount 968591 - This has power built in supplied by the cigarette lighter. Downside is you cannot attach any accessories to the sync port whilst in the cradle so you could not use a GPS mouse etc but fine for a BT GPS.
Pass Thru Mount 849591 - This replicates the port on the 4150 on the bottom of the cradle, you have to supply your own 12v power cabel but so long as it is suitable for a 4150 you just plug it into the cradle.
Passive Mount 848591 - No connections at all so you again supply your own cable but have to attach/detach each time you insert or remove the PPC.
You can see all these at www.brodit.com
Hope this helps!
cloudchaser
PostPosted: Fri Mar 26, 2004 7:49 pm    Post subject: Reply with quote
Doh.... now I know why I post on these forums ;)
I never figured out about the mounts and their being passive and active !!
How do these active mounts work? for example the - Active Mount 968591 - I assume the active mount is attached to the clip and stays. Do I just slot the PDA into it when required.
What kind of accessories woould someone plug in when driving? Also wouldnt this port be used in a passive mount when supplied by another power cable?
The Active Mount should suit me fine.... unless there is a similar quality and cost effective alternative. You recommend the Brodit for it high quality and ideally the alternative would be on par.
Thanks for all the great help so far, Darren - its much appreciated .... I am almost there ;) --- looking on Handnav site now.
PostPosted: Fri Mar 26, 2004 8:11 pm    Post subject: Reply with quote
Yes
What kind of accessories would someone plug in when driving? Also wouldnt this port be used in a passive mount when supplied by another power cable?
Not whilst driving but if you has opted for a GPS Mouse then you would need to choose either the passive or pass-thru mount, GPS Mice have a single connection which supplies power from the cigar lighter and data from the mouse.
The only other option aside from Brodit is Carcomm but they do not yet have a UK dsitributor nor a 41xx model, you will not be dissappointed with Brodit Smile
cloudchaser
PostPosted: Fri Mar 26, 2004 9:42 pm    Post subject: Reply with quote
The Brodit Active mount it is for me then. Have emailed Handnav with my query.
PostPosted: Fri Mar 26, 2004 9:49 pm    Post subject: Reply with quote
Do you know about our user group meet tomorrow near Junction 5 M3? You would be able to see a selection of Brodit mounts, a range of GPS receivers, PPC's and software etc and meet like minded users as well as representatives from some big names in GPS. I see you are based in London so it would be fairly local.
See here for details.
AlanW
PostPosted: Fri Mar 26, 2004 10:07 pm    Post subject: Reply with quote
See <a href="http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=6127">here<./a> for details.
Today's still friday Smile You mean Sunday Thumbs Up
Time flies like a bird. Fruit flies like a banana
PostPosted: Fri Mar 26, 2004 10:13 pm    Post subject: Reply with quote
Indeed I do, that'll teach me to post when I've been drinking wine! Of course that does mean I'll be the first one there........by 24hrs!!
cloudchaser
PostPosted: Sat Mar 27, 2004 10:53 am    Post subject: Reply with quote
Hi Darren
An extra 24hrs will give you ample time to stock up on the wine/pints and you sure will need your positining system afterwards !!
I knew about the meet but was not sure if I could make. I have now cancelled earlier engagement and will be there.
I need to put my kit order in before Monday and this is the best chance to be "initiated" into the world of GPS !!
Be prepared for lots of newbie questions !!
cheers
Raj
PostPosted: Sat Mar 27, 2004 10:55 am    Post subject: Reply with quote
Great :D Look forward to meeting you.
Page 2 of 2
22.094 (25 Sep 24)
