houghw Occasional Visitor
Joined: Mar 02, 2006 Posts: 31 Location: Cambridge, England
Posted: Mon Aug 20, 2007 4:40 pm Post subject: Converting favourites to POI's |
Does anyone know what file your favourites are saved in? And can the file be eddited?
If its possible to edit the file I was going to add it to the relative POI files and submit it to the forum.
Ta in advance
Wayne |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Mon Aug 20, 2007 5:20 pm Post subject: Re: Converting favourites to POI's |
houghw wrote: | Hi,
Ta in advance
Wayne | What device? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Tue Aug 21, 2007 8:17 am Post subject: |
Oops
I have a TomTom Go 500
Wayne |
Oldboy Pocket GPS Moderator
Posted: Tue Aug 21, 2007 9:37 am Post subject: |
It is the .cfg file in the Map Folder.
I believe you have an 'older' map version, in which case it will have the same name as the Map Folder.
In the later versions it is called MapSettings.cfg
It can be opened with POIEdit 2007, but that may not be much help to you.
You could delete the unwanted entries and save the result as an OV2 File, or you could convert them to a new POI using the Device itself.
I extracted the following from a previous Topic.
Andy_P2002 wrote: | Its a manual process so depending how many favourites you have, it will take a little bit of time.
1 ) First, create a new POI category (Preferences / Manage POI / Add POI category ). Call it "Favs" or whatever you like.
2 ) Then go Preferences / Manage POI / Add POI / Favourite / and select your first favourite.
3 ) Repeat step 2 for each of you favourites.
The POI file will be found in your map folder, called "Favs.ov2" (if that's what you called it). Just copy that file (and its matching .bmp icon file) to your friends machine's map folder and enable it in the manage POI menu. |
_________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Tue Aug 21, 2007 10:18 am Post subject: |
Thank you very much for answering my question for me.
I'll now upload a couple of updates I have from my favourites to the forum POI's.
Wayne |
