Pocket GPS World :: View topic - XDA Mini...
XDA Mini...
Stouffer
PostPosted: Sun Aug 19, 2007 1:49 pm    Post subject: XDA Mini... Reply with quote
I am using an XDA Mini and as anyone who has one will know, the speaker is lousy. I have now conected up a powered speaker which works a treat apart from one thing. The 2.5 jackplug socket sits about 15mm from the charging socket on the XDA so you get a constant high pitched whistle/whine similar to a mains hum which is pretty irritating Evil or Very Mad .
Does anyone know a way of getting rid of this? Or has anyone tried Ferrite rings, which have been suggested, as a possible cure?
TIA,
Andy.
PostPosted: Sun Aug 19, 2007 3:12 pm    Post subject: Reply with quote
The most probable cause for this is a term called "Ground Loop" to get rid of the noise you need to connect a ground loop isolator between the two devices, one such device can be found Here - Mike
