mickeyboy1 Occasional Visitor
Posted: Fri Aug 17, 2007 4:04 pm Post subject: camera alerts |
Hi all,
I copied all the files from my tomtom go 510 to the card on my wifes tomtom one, everything seems ok except i cannot get the camera alerts to work.
can anybody help me
many thanks mickeyboy1 |
radavis Regular Visitor
Joined: Mar 27, 2004 Posts: 132 Location: Woodford Green. Essex. UK
Posted: Fri Aug 17, 2007 5:29 pm Post subject: |
Are the camera files in the map directory?
Raymond |
Posted: Fri Aug 17, 2007 5:38 pm Post subject: |
Change Preferences/ Manage POI/ Warn When Near POI and the camera POI files should be listed, if not there is a problem with the files you have put on the device, or where you have put them.
Assuming they show up (scroll down the list to find them, or type PO on the keyboard to bring them to the top of the list) you will need to set up the warning parameters for each camera category you have installed to the One - Mike |
Posted: Fri Aug 17, 2007 10:21 pm Post subject: |
all the camera files are in the map directory |
Posted: Sat Aug 18, 2007 4:26 pm Post subject: |
hi mike, tried what you said but could not see the cams on poi's.
i have sent you a e-mail with a snapshot of the map folder ( hope you don't mind ). maybe you can see where i am going wrong
many thanks |
DennisN Tired Old Man
Posted: Sat Aug 18, 2007 5:13 pm Post subject: |
mickeyboy1 wrote: | hi mike, tried what you said but could not see the cams on poi's.
many thanks | It'll serve you right if he's gone out to the zoo!! No real harm done and this is NOT a telling off BUT ... Best post the listing here for all to see and dig into - could well get a faster reply. Most of all, somebody else has had, or will have the same problem and if they see it solved here, they'll reap the benefit of your posts. That's why we encourage public posting - you wouldn't believe the stuff I've picked up by reading other people's posts. _________________ Dennis
Two of them are obesiting!! |
FazerUK Lifetime Member
Joined: Nov 18, 2004 Posts: 242 Location: Wrexhaml, UK
Do you have only one map folder? if you have more then one map folder make sure the camera database is in both _________________ TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127 |
Posted: Sat Aug 18, 2007 5:19 pm Post subject: |
Problem is the poor chap doesn't know how to post a picture up on the site, I am still awaiting an e-mail with a picture then I will link it to this thread so everyone can have a read/ look and work out what the issue is - I seem to remember helping out a few others with the issue of posting pictures, so he isn't the only one who finds this troublesome - it easy to do when you know how but it can cause severe nashing of the teeth when you don't.
And while Blackpool does have a Zoo I have not gone there for quite a while - Mike |
Posted: Sat Aug 18, 2007 5:52 pm Post subject: |
my sincerest apologies to all for being a thickie, i will get the hang of this eventually ( I hope )
Edit once to add picture as per the request - Mike Alder |
Posted: Sat Aug 18, 2007 6:55 pm Post subject: |
Have a look at #7 on the FAQ Page it will explain exactly what is wrong, in short you cannot configure camera warnings when using the TomTom supplied camera database, use the one from this site instead as it is more accurate and considerably cheaper you can also use full spoken alerts and configure the warnings with the Pocket GPS World offering - Mike |
Posted: Sat Aug 18, 2007 7:08 pm Post subject: |
mikealder wrote: | I seem to remember helping out a few others with the issue of posting pictures | INCLUDING ME! You will perhaps recall I took some getting through to? But you're right, easy when you know how. _________________ Dennis
Posted: Sun Aug 19, 2007 12:46 pm Post subject: |
thanks mike, it makes sense now, i will download the database as you sugest. |
Posted: Sun Aug 19, 2007 1:11 pm Post subject: |
hello again, i have downloaded the camera database and following instructions on screen, the thing is do i have to delete the tomtom cameras from my card prior to loading the new ones or leave them there,
thanks again |
Posted: Sun Aug 19, 2007 1:14 pm Post subject: |
Have another read of the FAQ page (the link to it is in my previous post) this time you want to read #13 which details how to remove the TomTom cameras.
It is possible to have them both on the device but the warnings can get messed up with duplicate entries from each database trying to offer warnings, the easy option is to make sure you have a back up of the device then remove the TomTom cameras from the device - Mike |
Posted: Mon Aug 20, 2007 2:00 pm Post subject: |
thanks for the info, everything is working perfectly now
cheers |
