Pocket GPS World :: View topic - TTN6 WM6 com port problem
mtmiddleton
PostPosted: Sat Aug 18, 2007 10:32 am    Post subject: TTN6 WM6 com port problem Reply with quote
I have just bought and installed TTN6 on a HTC TYTN running WM6.
tomtom loaded fine, but I wanted to keep using my wired tomtom GPS, so a bought a Brodit car holder with a splitter to power both the receiver and the TYTN.
The trouble is I only ever get the message "no gps device". Does anybody know which program/hardware ports I need to select in the WM6 external gps program ?. I am assuming this is the problem of cause.
PostPosted: Sat Aug 18, 2007 10:36 am    Post subject: Reply with quote
Welcome to the forum, you cannot use a wired GPS with that type of PDA Phone as it doesn't have a com port the only way forward is to use a Bluetooth GPS - Mike
mtmiddleton
PostPosted: Sat Aug 18, 2007 10:40 am    Post subject: Reply with quote
I was scared you might say that.
Do you know if I can get a BT receiver that can be charged in car?
thanks for your help.
Mark
PostPosted: Sat Aug 18, 2007 10:45 am    Post subject: Reply with quote
If you get a BT GPS with a mini USB socket for charging you can use the car charger lead that you use with the Tytn, I would go for one with 30 Hours battery life though, so in car charging isn't that important, check out the iBlue units - Mike
mtmiddleton
PostPosted: Sat Aug 18, 2007 10:48 am    Post subject: Reply with quote
Will do.
Thanks again.
Mark
22.063 (19 Jun 24)
