thekirbyfake Occasional Visitor
Joined: May 10, 2004 Posts: 38 Location: UK (in the Sarf)
Posted: Fri Aug 10, 2007 5:01 pm Post subject: Warn when closer than: Grrrrr |
I've recently moved from TTN5 to TTN6 and copied over my POIs.
Whenever I try to add something new to one of the POI categories it always asks "Warn when closer than...".
It's a client, not a speed camera so I don't need any more warning than "You have reached your destination".
Any ideas how you can turn this off.
I know you can go into Manage POIs and remove the warning for an entire category but when you add something new to that category the annoying "Warn when closer than..." message comes up.
Grrrr. _________________ HP iPAQ 2210; TT5 wired; 256Mb Kingston CF; 256Mb Viking SD; Arkon Powered Speaker Mount
HTC TyTn; TT6 BT; 1Gb SanDisk MicroSD |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Fri Aug 10, 2007 8:19 pm Post subject: Re: Warn when closer than: Grrrrr |
thekirbyfake wrote: | I've recently moved from TTN5 to TTN6 and copied over my POIs.
Grrrr. | I've also copied POIs from TT5 to TT6 recently. I have NOT seen this behaviour! _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
vroomfondel Regular Visitor
Posted: Fri Aug 10, 2007 9:01 pm Post subject: |
I've noticed that and thought it I was doing something wrong.
When adding a new POI to an existing category it first wants to turn on the warning when near. Even when that category doesn't already have the warning already turned on. Mildly annoying..
This is on TTNavigator6.030.8030 |
martike Regular Visitor
Posted: Wed Aug 15, 2007 2:34 pm Post subject: |
There are different ways to add a POI to an existing category. The User Guide takes you through Change Preferences, Manage POIs, Add POI, then a choice of specifying your POI which includes a point on the map. i.e. you decide first what you want to do, then select where you want to do it.
But the more usual way (for me anyway) to do it is to be already positioned at a point on the map and want to have it remembered as a POI. i.e. you already have the location and want to specify what to do. This is when the sequence for adding a warning takes over. It’s not logical and it’s annoying.
However, all you need to do is select “cancel” and the screen you get next again has “Add POI” as one of the options. This one allows you to add a “simple POI” without warnings. It does, though, only seem to offer the categories you’ve added yourself, not all the available standard categories. |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Posted: Thu Aug 16, 2007 11:55 am Post subject: |
thekirbyfake wrote
Quote: | Whenever I try to add something new to one of the POI categories it always asks "Warn when closer than...". |
I think I saw a thread on the same subject a while ago, and the conclusion was that this is a bug in tt6 ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) _________________ TT Go Essential |
