Pocket GPS World :: View topic - tt 720 memory options
kalvin928s4
PostPosted: Tue Aug 14, 2007 6:09 am    Post subject: tt 720 memory options Reply with quote
hi can someone confirm that this unit has 2gb internal memory flash card? and i can also use sd cards... presumbly for putting my mp3's on? if so does itt matter on what size memory card? i.e 8gb or will it only 'allow' upto certain size? many thx
PostPosted: Tue Aug 14, 2007 7:19 am    Post subject: Reply with quote
Yes the 720 has 2GB of internal memory although it is not on a crad as such it is PCB mounted. You can use an SD card with the device to supplement the available memory, make sure it is a good quality high speed card or the device will probably reject it, I don't think you can go any larger than 4GB as a max card size, but I have not tried as yet - Mike
Tim Buxton
PostPosted: Tue Aug 14, 2007 8:46 am    Post subject: Reply with quote
Just for info., Darren tried an 8Gb SDHC ard in his 720 and it wasn't recognised.
Tim
grahambaines
PostPosted: Tue Aug 14, 2007 11:29 pm    Post subject: Bigger SD card Reply with quote
My TT 1 gig SD card is showing almost full. I will need more POI's so I bought a 2 gig Sandisk SD Ultra 11. I have tried to copy the TT card to the new card but on reboot TT says this software not registered. So I wiped the new card and tried TT Home back up and restore to the new card, Home won't write back tp it. Any ideas please.
PostPosted: Wed Aug 15, 2007 7:45 am    Post subject: Reply with quote
Have a read of the FAQ pages which can be found Here you should read #1 #2 #8 and possibly #14 - Mike
grahambaines
PostPosted: Wed Aug 15, 2007 6:08 pm    Post subject: Bigger SD card Reply with quote
Thanks MIke, I read and did all that and all seemd to work UNTIL I booted up and got the "This product has not been activated, your device code is etc and visit www.TTcode.com". Should I re activate on this card and will this render my TT card inoperable should I need to backtrack?
Thanks for all help.
PostPosted: Wed Aug 15, 2007 6:11 pm    Post subject: Reply with quote
Have another read of FAQ #14 (use the link in my post above to get to the FAQ page) as that is the most probable cause - Mike
grahambaines
PostPosted: Wed Aug 15, 2007 7:08 pm    Post subject: Bigger SD card Reply with quote
Thanks Mike, I think the clue is at the bottom. I did not realize you could activate more than one card simultaneously. I'll give it a try.
grahambaines
PostPosted: Wed Aug 15, 2007 11:52 pm    Post subject: Bigger SD Card Reply with quote
All sorted Mike, my grateful thanks. Brill forum, hope I can help sometime.
22.055 (29 May 24)
