Pocket GPS World :: View topic - Myguide 3100
Myguide 3100
peasemore
PostPosted: Mon Aug 13, 2007 8:55 am    Post subject: settings Reply with quote
As I copied bmp's across can't say if behaves without MaFt. Mad
Re MyGuide camera settings
Go to
Settings
General Settings
Speed Warning Options
Enable Safety Cameras
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Mon Aug 13, 2007 9:06 am    Post subject: Reply with quote
thanks peasemore
can you also confirm that you copy the files to the sd card (as per http://www.pocketgpsworld.com/uksafetycameras-igo-myguide-oncourse_navigator.php ) and don't need to do anything with the internal memory?
SirJuicer
PostPosted: Mon Aug 13, 2007 9:59 am    Post subject: Reply with quote
MaFt wrote:
thanks peasemore
Hey MaFt,
I copied the contents of the .zip to \Flash Disk\MyGuide\POI\SPEEDCAM which I don't think is actually the sd card, I think it's the memory of the unit. The following folders are in view when I open up "explore" from ActiveSync;
Flash Disk
My Documents - contains recent routes
Network - empty
Program Files - empty
Storage Card - (SD Card?) contains maps (\Storage Card\MyGuide\MAPS)
Temp - empty
Windows - contains program files for CE
Not sure if this helps or not.
- Craig.
PostPosted: Mon Aug 13, 2007 11:08 am    Post subject: Reply with quote
- Craig.
yes, it does! seems i have wrongly assumed that flash disk is the sd card...!!
thanks
crossfordkid
PostPosted: Tue Aug 14, 2007 9:18 pm    Post subject: 'consolidated by type' Reply with quote
MaFt wrote:
would it be beneficial for you lot to have a 'consolidated by type' download? i.e. so you can have different icons for each camera type? so you can distinguish between mobile, gatso, redlight etc or do you get some kind of guidance anyway? i know the format has camera type embedded in the data but not sure how igo uses it
Hi to MaFt,
Any news on the above - I basically only want the fixed loactions ... not the mobile ones. I've tried splitting the type 5s from the txt file, but it will takes ages as the types are mixed nearer the end of the file.
Cheers.
PostPosted: Wed Aug 15, 2007 9:16 am    Post subject: Reply with quote
hi, i've had a lot on but will try to get it added for the next release
bbdez
PostPosted: Wed Aug 15, 2007 8:48 pm    Post subject: Reply with quote
hi all, i now have the 3100 too and i have added the 4 files into the folder as it say, i have soft reset, enabled unenables and soft reset again and i dont have any speed camera's on mine, is there anything else that needs dun.
i am sorry i have read all here but am still stuck, the version is
679804-pgpsw-speed-cams , and the files are
pocketgps_uk_pmobile (both text and bitmap)
pocketgps_uk_sc (both text and bitmap)
also when i did try to add them it said sum error about only being able to transport the files as they were not compatable or sumthing ???
can sumone plz help me, thx very much for reading
bbdez
PostPosted: Wed Aug 15, 2007 9:07 pm    Post subject: Reply with quote
ok now i have downloaded the myguide again, it is a different file number but this time it has worked, sorry for any trouble
PostPosted: Thu Aug 16, 2007 8:16 am    Post subject: Re: 'consolidated by type' Reply with quote
crossfordkid wrote:
Hi to MaFt,
Cheers.
done now
crossfordkid
PostPosted: Thu Aug 16, 2007 9:34 am    Post subject: Reply with quote
Thanks MaFt,
Just downloaded the 'consolidated by type'
Perfect, just what I wanted .... all loaded except the mobiles.
Thanks again. Very Happy
hydie331
PostPosted: Thu Aug 16, 2007 9:12 pm    Post subject: Map Updates Reply with quote
Hi, does anyone know if there are any map updates for the Myguide 3100. If so were can i get them from? I also need a mains charger if anyone can help?
M Hyde
bbdez
PostPosted: Fri Aug 17, 2007 7:09 pm    Post subject: Reply with quote
other thing i am trying to do is convert (if needed) and put more poi on my 3100 but dunno how ? Laughing Out Loud sorry but does anyone know how, i tried a couple of progs to convert navman and tomtom but i dont know wot fomat to convert to and i tried putting them in the same place as the cams, but i can find them on the unit....
plz help me, thx alot
bbdez
PostPosted: Fri Aug 17, 2007 7:13 pm    Post subject: Reply with quote
sorry posted in wrong area
hydie331
PostPosted: Sun Sep 02, 2007 6:57 pm    Post subject: Myguide against Igo data base Reply with quote
Hi, as anyone noticed that the Myguide 3100 does not show any visual alerts when using the Myguide speed camera database. However when using the Igo database there are visual alarts? Unless i have done something wrong.
Also as anyone come across any map updates for the 3100 as my software on the Sd card is dated November 2006.
M Hyde
Buffdaddy
PostPosted: Sun Sep 02, 2007 7:13 pm    Post subject: Myguide against Igo data base Reply with quote
Can you explain what you been by Myguide speed camera database. Do you mean the pocketgps speedcamera database?
The pocket gps speedcam database does give you visual alerts usually in the centre of you screen.You should see the image of a camera displayed plus the speed limit. For example, if the speed limit is 30mph, the visual warning displays 29mph. This remains till you have gone past the camera. For myguide cameras that you have input yourself via POI ,,,add camera, you get a visual alert. All you will see is the speed limit encased in a circle.
Page 3 of 4
