peasemore Lifetime Member
Posted: Sat Aug 04, 2007 8:02 am Post subject: Updating advice valued :) |
Following instruction I unzipped file, but do you copy all the .txt files across to device including "Licence " + "Release" ones too??
And is anything done with the camera images; do they go in too?
Thanks _________________ Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve. |
Posted: Sat Aug 04, 2007 8:35 am Post subject: |
You just need the data files (csv, ov2 etc depending upon what data type is correct for your device) and bmp files, you do not need the help or release/ licence txt on the nav unit - Mike |
Andy_P Pocket GPS Moderator
Posted: Mon Aug 06, 2007 1:50 am Post subject: |
And when you update next time, you can leave the .bmp pictures as they don't change.
Just copy the new csv or ov2 files into the same place and say "Yes" when windows asks if you want to overwrite the files that have the same name. |
Posted: Sat Aug 11, 2007 11:53 am Post subject: Which .txt files?? |
Thanks all.
Maybe the instructions page instead of saying copy all .txt files, should have a rider,
excluding 2 that I mentioned.
May assist other newbies _________________ Gel
JockTamsonsBairn Lifetime Member
Posted: Sat Aug 11, 2007 1:27 pm Post subject: Re: Which .txt files?? |
peasemore wrote: | Thanks all.
May assist other newbies |
I think it is actually better for newbies to be told
"4. Copy the extracted .txt files to this folder"
rather than
"4. Copy the extracted pocketgps_uk_pmobile.txt and pocketgps_uk_sc.txt files to this folder. (You can ignore the Licence.txt and release.txt files.)".
But you're right, the Licence.txt and release.txt files are not required to be copied over.
As regards the peasemore wrote: | And is anything done with the camera images; do they go in too? | I'm not familiar with MyGuide. Without copying the BMPs over, do you get a camera icon displayed? If not, do you get an icon displayed once you've copied over the BMPs?
If you can post back, one of the team can update the Instructions. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sat Aug 11, 2007 2:34 pm Post subject: Camera icons |
Can't say as I copied txt and bmp's across all at once.
I did add a local camera manually before adding the database, and
that produced a speed camera icon on map. _________________ Gel
Posted: Sat Aug 11, 2007 2:37 pm Post subject: |
Quote: | I did add a local camera manually before adding the database, and
that produced a speed camera icon on map. |
Have you submitted it? CLICK HERE |
Posted: Sat Aug 11, 2007 2:56 pm Post subject: Camera |
Glad to say didn't need to
PaulB2005 wrote: | Quote: | I did add a local camera manually before adding the database, and
Posted: Sat Aug 11, 2007 2:59 pm Post subject: |
Someone else beat you to it? |
