Steven0161 Occasional Visitor
Posted: Fri Aug 10, 2007 8:03 pm Post subject: MapSettings.cfg to TT520 |
I am thinking of upgrading from TT One V2 to the TT 520..can anyone confirm if the MapSettings.cfg will work from TT One to the 520
cheers ![Surprised](modules/Forums/images/smiles/icon_surprised.gif) |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Sat Aug 11, 2007 1:09 am Post subject: Re: MapSettings.cfg to TT520 |
Steven0161 wrote: | I am thinking of upgrading from TT One V2 to the TT 520..can anyone confirm if the MapSettings.cfg will work from TT One to the 520
cheers ![Surprised](modules/Forums/images/smiles/icon_surprised.gif) | Yes it should. I'd advise you (after first doing complete backup of 520 using Windows Explorer) to create something (a dud favourite) in the new map in order to get a poor .cfg file (the device doesn't have one out of the box) for which you can check the correct filename - TT have been changing them recently, so you may need to rename the one you want to copy across.
My 720 one is called MapSettings.cfg, just like the one on your TT One V2, so with luck it won't need renaming. _________________ Dennis
Two of them are obesiting!! |
mpwilson99 Lifetime Member
![](modules/Forums/images/avatars/15509806134a81c3cd19d71.jpg)
Joined: Jun 30, 2007 Posts: 462 Location: Hickstead, Sussex
Posted: Sat Aug 11, 2007 9:47 am Post subject: |
If its the same as a TT720 then yes it should,
However with my preset POI warning sounds i had to reselect them all. All the disatances and favs were the same though but it was a pain redoing 104 poi again!
cheers |
Posted: Sat Aug 11, 2007 10:17 am Post subject: |
mpwilson99 wrote: | it was a pain redoing 104 poi again! |
104?? Isn't the limit 100?? (although I haven't heard in relation to Navcore 7, it was 100 with v6.) _________________ Dennis
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Aug 11, 2007 11:11 am Post subject: |
I have read the limit is 100 but not tried that test yet on my device, that said it is possible to configure more than 100 custom POI, BUT the device will only use 100 of them that it chooses.
If I were you I would do a very thorough check as to which POI files are enabled for warning on the device - make sure all your Specs Cameras are present and correct as for some reason the devices seem to drop these POI first when you exceed 100. - Mike |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sat Aug 11, 2007 1:19 pm Post subject: |
DennisN wrote: | mpwilson99 wrote: | it was a pain redoing 104 poi again! |
104?? Isn't the limit 100?? | Could be using the built-in POIs. They don't count towards the 100. ;) _________________ Richard
Posted: Sat Aug 11, 2007 1:29 pm Post subject: |
Oldboy wrote: | Could be using the built-in POIs. | Well, I suppose somebody must be. I even met somebody the other day who was happy about TT speed camera database. No accounting for folk. Or as they say, "All the world's queer, except thee an' me. An' even tha's a bit queer." _________________ Dennis
Posted: Sat Aug 11, 2007 1:35 pm Post subject: |
Hi all
YES i do mean 104, made up of 100 my own POI and 4 Tomtom preinstalled ones. You can have as many POI showing as you like, as long as you only have upto 100 of your own ones installed.
If you copy across your current mapsetting file, and then goto warn POI, then it will pick up you have a warning setting but it will default it to a next opportunity setting. i dont know why it wont give you the sound setting, very annoying!
Anyways, i have now managed to `break` my tomtom 720 version 3!
Going back to currys again later!
I have also filmed photographic evience of this bug so will get it on youtubes or something later.
MPW |
Andy_P Pocket GPS Moderator
Posted: Sun Sep 02, 2007 7:13 pm Post subject: |
I DID have problems after I copied my MapSettings.cfg from a Go x00 series to my new 720.
The installed TTS voice disappeared, as did all speech recognition.
Fairly sure that was the cause, and I had to do a restore to my "day one" back-up to get them back. |
