Pocket GPS World :: View topic - TT720+ Speed Camera's
chelsky
PostPosted: Thu Aug 09, 2007 7:59 pm    Post subject: TT720+ Speed Camera's Reply with quote
Hi, I have downloaded the UK camera warnings and the .ogg files + the eu ones. I also printed off Mike's guide for the installation of said files. I followed the instructions up to the distance. Did that but the next screen did not give me the option to select Sound Effect but just said something like Do You Want To Use the selected sound? I said yes. So far so good. I put in a route to Maidstone in Kent where I knew there was a camera and I got the 30mph warning + 2 I didn't know about!!!!
Problems: I now have files on my SD card although all the speed camera files are on the TT720!!!
This is proberly a dumb question, but I could't enter a warning distance for the .tba,.var. red light and Spects 20 to 70. There is proberly a good reason for this, but I have read and reread the forums and have missed the explaination for this.
Question. Why are there files on my SD card and can I format it to clear it
Thank you in advanced. David
PostPosted: Thu Aug 09, 2007 8:02 pm    Post subject: Reply with quote
Exactly which files have you "found" on the SD card? - can you list them please as this will aid diagnosis further - Mike
chelsky
PostPosted: Thu Aug 09, 2007 8:06 pm    Post subject: Reply with quote
What a resonse Mike!!! List will follow in a minute. David
chelsky
PostPosted: Thu Aug 09, 2007 8:21 pm    Post subject: Reply with quote
Hi Mike, here is the list:
ASR
bin
contacts(empty)
fleetecd
gns
itn
login (empty)
LoquentoTTs
sounds(empty)
statdata
zip
clmdata
currentmap.dat
fm2010parameters
fmsignal
install.bif
libaec.so
settings.dat
system
tottom.ico
ttdesk.ver
ttgo.bif
ttpnpd log
tt system
userpatch.dat
PostPosted: Thu Aug 09, 2007 9:27 pm    Post subject: Reply with quote
Can you remove the SD card and see if the device will still boot up and work, if it does, do the missing speed cameras show up without the SD card installed - Mike
chelsky
PostPosted: Thu Aug 09, 2007 10:04 pm    Post subject: Reply with quote
Hello Mike, Yes it still boots up without the SD card and I can still find the specs camera's but I can't set a warning distance for them. Do I try and set a distance for the red lights?
Regards David
PostPosted: Thu Aug 09, 2007 10:10 pm    Post subject: Reply with quote
There is no harm in trying to set up the red light camera warning - what exactly does the unit do when you select a Specs camera from the list when configuring the warnings, can you tell us what you see on the screen and how far you get through the sequence - Mike
chelsky
PostPosted: Thu Aug 09, 2007 10:16 pm    Post subject: Reply with quote
I pick say Specs 20 then I get the screen to set the distance, so for Specs 20 I type in 200yds click ok then nothing. Just sits there.
chelsky
PostPosted: Fri Aug 10, 2007 8:28 am    Post subject: Reply with quote
Should I have configured the camera's for distance before I installed the .ogg files? Just a thought.
chelsky
PostPosted: Fri Aug 10, 2007 9:13 am    Post subject: Reply with quote
Hello Mike. This morning I switched on my TT720, tried to set the distances and it worked. All the Specs are now configured. Did this with the SD card out. All the files on the SD card seem to be a clone of the ones on the TT. Do you think it would be ok to format the card now?
22.063 (19 Jun 24)
