peasemore Lifetime Member
Posted: Wed Aug 08, 2007 6:32 pm Post subject: Speed cameras not showing ~MY GUIDE 4200 (Bought last week) |
I've downloaded the .txt +.bmp files for above, from here and copied to
\Flash Disk\MyGuide\poi\speedcam
pocketgps eur pmobile (bmp)
" " " " (txt)
" " sc (bmp)
" " " (txt)
pocketgps uk pmobile (bmp)
" " " (txt)
pocketgps uk sc(bmp)
" " " (txt)
Database is only one showing for My Guide ie 671239-pgpsw-speed-cams
I've switched on and off, but the cameras do not show; any advice pse
Safety Cameras in enabled in settings;I assume they should be showing even when using at desk to plan a route? _________________ Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15161 Location: Bradford, West Yorkshire
Posted: Thu Aug 09, 2007 9:26 am Post subject: |
you need to unzip this file: 671239-pgpsw-speed-cams
in xp you can right-click and choose 'extract to...'
MaFt |
Posted: Thu Aug 09, 2007 10:15 am Post subject: Speed cameras not showing ~CRACKED |
THANKS, had done all that, but found a cure.
On back of unit is a recessed slider on/off button.
Switching on and off has cured.
I assumed soft reset mentioned in instructions was using
normal on/off switch on top of unit.
MaFt wrote: | you need to unzip this file: 671239-pgpsw-speed-cams
MaFt |
Posted: Thu Aug 09, 2007 10:39 am Post subject: |
sorry, when you mentioned the zip-file name i presumed you had added the actual file rather than it's contents (happens a lot!)
i trust it's sorted then? do you think it's worth adding the 'slide reset' to the instructions? if so, how exactly would you want it wording?!
MaFt |
