Pocket GPS World :: View topic - HP Announce 221x ROM Update
PostPosted: Tue Mar 23, 2004 9:46 pm    Post subject: Reply with quote
Nope sorry you can't! You can backup data files, etc but not apps that have registry entries etc.
Look at it as a good opportunity to give your system a spring clean!
icsys
PostPosted: Wed Mar 24, 2004 12:37 am    Post subject: Reply with quote
Well I thought I would do it.
So far I notice I have lost the currency converter, but I have gained a new default Theme.
PostPosted: Wed Mar 24, 2004 8:35 am    Post subject: Reply with quote
Well spotted, I hadn't notice the calculator had lost it's converter, I quite liked that although it never remembered exchange rates!
thedon
PostPosted: Wed Mar 24, 2004 10:18 am    Post subject: Reply with quote
i installed the rom upgrade last night, only took about an hour to do rom, reinstall all apps, reset preferences, and restore data / patches etc.
2210 seems a bit quicker, theme is now a plain blue, and best of all my wi-fi card / zero config. connection works a lot better.
nb. don't forget to secure your TT2 favourite locations as POI's.
aliendad
PostPosted: Fri Mar 26, 2004 2:04 pm    Post subject: ipaq upgrade and tomtom2 maps Reply with quote
Sad i have upgraded my hp2210 and since doing that i can only use tomtom2 if a map is on the main memory? (sd card maps not recognised!)
if no map is installed on the main memory starting tomtom2 brings up a screen saying no maps found?
i am using an sd card and all was fine before upgrade?
hhhheeeeeeellllllpppppp!!!!!!!!!!!!!
or help for short
PostPosted: Fri Mar 26, 2004 2:49 pm    Post subject: Reply with quote
Can you see data on the storage card using file explorer? Simplest way around this is to format the storage card and re-install the maps. if you do this then don't forget to back-up any custom POIs before hand.
Another option would be to use SoftWinters Storage Tools to give the SD Card a health check, it's available here.
aliendad
PostPosted: Fri Mar 26, 2004 5:16 pm    Post subject: where is my map? Reply with quote
in reply, yes can see files etc,
will do card check
thanks for advice
but point is all was ok before upgrade and card has not been altered?
PostPosted: Fri Mar 26, 2004 5:37 pm    Post subject: Reply with quote
Unless you have any way of verifying that the card can be read successfully in other devices then I suspect that it is just a corrupted map which could be a coincidence.
Before you format it may be worth simply re-installing your chosen map to the card and seeing if this resolves matters?
aliendad
PostPosted: Fri Mar 26, 2004 6:13 pm    Post subject: Reply with quote
tried reinstaling map and still not found, however if small enough map installed to main memory then transfered to sd card, all ok.
but ofcourse can`t install whole of uk as one map via main unit.
PostPosted: Fri Mar 26, 2004 6:30 pm    Post subject: Reply with quote
There is something very odd going on here! Have you checked the card using that utility yet?
aliendad
PostPosted: Fri Mar 26, 2004 6:40 pm    Post subject: Reply with quote
at work at the moment, will check when get home tonight
im confused as well?
PostPosted: Fri Mar 26, 2004 6:50 pm    Post subject: Reply with quote
I think you would be best to run Storage Tools to check the card and then format it afresh. Re-load the maps and see where we are at.
What make is the SD card?
Clarkey
PostPosted: Fri Mar 26, 2004 11:54 pm    Post subject: Reply with quote
Don't know if it matters & it's a bit late to mention now but I took my SD card out before performing the upgrade and have had no problems. Just popped the card back once TomTom was reinstalled and everything worked fine. Didn't have to reinstall the maps on the card.
Adrian (feeling smug that just for once something went right)
PostPosted: Sat Mar 27, 2004 9:20 am    Post subject: Reply with quote
It should make no difference to the application of the ROM upgrade. I left both my Cf and SD cards inserted whilst the upgrade took place and it all went smoothly.
Iain51
PostPosted: Sat Mar 27, 2004 12:07 pm    Post subject: Reply with quote
aliendad, do you have any software on the SD card that is run on start-up? I ask because I have read about an issue with the upgrade where because the OS can't see the card quickly enough it creates a folder called SD Card. Then, when the SD card does come online it gets called SD Card2. Should be easy enough to check.
Iain
Page 2 of 3
22.105 (30 Oct 24)
