Pocket GPS World :: View topic - TomTom GO 720's Start Shipping
Goto page Previous  1, 2, 3 ... 20, 21, 22 ... 28, 29, 30  Next
SpeedCam
PostPosted: Sat Aug 04, 2007 10:53 am    Post subject: Reply with quote
A few problems are starting to appear, SD cards, Help ME POI & Handfree, as these devices were probably manufactured over three months ago ( Made in China, shipping time, customs, distribution etc ) lets hope there's an update made available very quickly to solve these problems.
PostPosted: Sat Aug 04, 2007 10:56 am    Post subject: Reply with quote
I've tried all my SD cards and all except my 8Gb SDHC card work fine. What's the issue with Handsfree?
Pads
PostPosted: Sat Aug 04, 2007 11:01 am    Post subject: Reply with quote
Hi 0 there is no product code. When I logged on via HOME the software noted I was not using my ONE NE and asked if I wanted to register the new TT720. It automatically updated and put the product code fte. into my profile.
homersolly
PostPosted: Sat Aug 04, 2007 11:03 am    Post subject: Reply with quote
Hi Darren,,
Have you been able to get mp3's on your sd card to play okay on the 720?
Also if I play mp3's via tomtom using FM transmitter will the music be interupted for any directions given?
Thansk
Kevo
Very Happy
PostPosted: Sat Aug 04, 2007 11:46 am    Post subject: Reply with quote
Yes, loaded a few just now to test and they all played fine. I manually craeted the mp3 folder on the memory card and copied the .mp3's into there. I've also experimented using HOME to see if that is the cause but those files are copied and played Ok also. The only difference with HOME is it creates a folder structure in the MP3 folder for the artists etc.
Yes, the music is paused whilst the turn instructions are given.
ferretdiver
PostPosted: Sat Aug 04, 2007 1:19 pm    Post subject: Reply with quote
Moved the MP3's onto the SD Card using Tomtom Home, they all now appear in individual folders on the card when in the 720. They will play individually but not one after the other. It is like they are all individual play lists. When I put the card in a card reader, nothing shows up on the card. But the music is definitely on the SD card as it doesn't show on the 720 when the card is removed. I am obviously doing something wrong !
Ian.
SpeedCam
PostPosted: Sat Aug 04, 2007 4:36 pm    Post subject: Reply with quote
The handsfree problem is here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=58178
The SD cards, when they worked I was able to play MP3 files if they were stored in the correct location \MP3\....
I've tried the following cards:
Sandisk Extreme II 4Gb, this was recognised, and both maps & MP3 files were OK.
Viking 2GB (Rebranded Panasonic) also recognised correctly.
Kingston 256Mb also recognised correctly.
The problem does not appear to be with the cards but the boot process, if these cards are in the 720 when booting an animated image shows you having to remove the card and then a big 'X' appears across the image of the SD card.
My 720 is next to useless since using the Sandisk card, ever since this was inserted I've received 'Unable to store settings, file access error', after which the 720 works OK, I can the power it off and on once and its OK, the second time I power it on it hangs requiring a reset. As the settings were not saved the startup routine starts again.
I have now formatted the internal disk many times and restored both my own back and the one from the Home application. Everytime I get the access error during the setup routine after select the voice type, and this is without an SD card inserted. I suspect that maybe it is trying to write to some internal storage/flash, not the 2GB internal drive. I've now run out of ideas.
It would be good if there was a hard reset option to clear everything both internal disk & and flash memory.
ferretdiver
PostPosted: Sat Aug 04, 2007 6:41 pm    Post subject: Reply with quote
I get the same message/image, so it would appear there is problem with the SD cards in the 720
teecee90
PostPosted: Sat Aug 04, 2007 7:54 pm    Post subject: Reply with quote
Is it necessary to register the 720 on the tomtom web site? If so, I seem to remember DennisN saying that there were problems registering if you had more than one tomtom device.......is that right?
Is it possible to transfer my traffic subscription to the 720 ?
forky
PostPosted: Sat Aug 04, 2007 8:31 pm    Post subject: Reply with quote
I have the same problem you can only register 1 device with tomtom
I tried de-registering my 510 but that didn't work so have emailed tomtom for advice
Garmin Nuvi 2699lmt
Samsung Galaxy S9 (o2) contract
technik
PostPosted: Sat Aug 04, 2007 9:31 pm    Post subject: Reply with quote
The traffic issue.
Go to TomTom Plus services site and login.
Select reset traffic service.
You can now enable traffic on your 720
Worked for me.
Once enabled plus services shows you as having a 720.
The registering product did not work for me, but is no big deal.
PostPosted: Sat Aug 04, 2007 10:40 pm    Post subject: Reply with quote
My problem was that TT require you to have a different account for each device, meaning you need a different e-mail address for each device. Their actual words to me were "If you have five devices, you need five accounts" (and like I said, each account needs its own email address). However, as I understand it, if you dump one device, you can change your account to contain the new device.
My difficulty with this was - if I set up two (indeed now with my new 720, three) email addresses, how do I see if I've got an email? Do I have to continually switch email signups all the day long? Is this an easy situation for all you clever people with many email addresses?
technik
PostPosted: Sat Aug 04, 2007 11:03 pm    Post subject: Reply with quote
You could have a million email accounts for all it matters, but you don't need to check all 1 million email accounts unless you are expecting anything except junk mail.
If you only need a different account just to register a product I would not bother, as what is the benefit?
PostPosted: Sat Aug 04, 2007 11:22 pm    Post subject: Reply with quote
No benefit to me, none at all. But a pain in the doings. To login to TT for the correct device, I need to use the correct email address and password. I now have three and back when I tried to have the second, I managed to cock it up and ended up with both the maps I bought by download on 17th April registered to only ONE device and TT quite simply don't want to know to help me put it right!! I tried to tell them I didn't need two v675 Europe maps on the same device, but one on each of two. Eventually they told me if I had a complaint I could write to Holland!!! So officially, one of my devices doesn't have a legal map, even though I have a receipt for it from Tom Tom.
My three devices have different MAP versions - ALL THREE with "THE LATEST MAP", all different!! Rolling Eyes
SPORTSMAN
PostPosted: Sun Aug 05, 2007 9:38 pm    Post subject: Reply with quote
Can someone tel me how to put pictures onto my 720. Rolling Eyes
Page 21 of 30
