MikeB Frequent Visitor
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Mike.png)
Posted: Wed Jun 20, 2007 9:45 am Post subject: Emtac mini-S3 bluetooth GPS receiver review |
The first Bluetooth GPS receiver that I reviewed was the original Emtac Bluetooth GPS way back in 2002. At the time this was the first Bluetooth GPS and it stood the test of time. Transplant introduced this GPS receiver in the USA.
Over the years the Emtac brand has changed hands and is now distributed worldwide by Transplant. In that time a number of BT GPS receivers have been released. The most recent and the subject of this review is the Emtac Mini S3 Bluetooth Receiver.
The Emtac mini-S3 is the smallest of the Emtac Bluetooth GPS receivers to date, but does its size affect it's performance?
Click here to read the full review. _________________ Mike Barrett
phantom Occasional Visitor
![](modules/Forums/images/avatars/avatar_sp_018.jpg)
Joined: Oct 17, 2003 Posts: 30 Location: Berkshire, UK
Posted: Tue Jul 03, 2007 5:31 pm Post subject: |
I am using an original Emtac Bluetooth GPS with an iPac and Destinator PN. The original is still operating well but at £70 (not bank breaking) I wonder if I should buy a new one. What improvements should I expect, I gather from your review that I will get a fast fix at new starting points, that must be good since I,ve just come back from Switzerland/Italy/France alpine area and often had to stop for a new fix when passing from country to country through long tunnels.
Would the new Emtac be more accurate for positioning compared with the original. In Paris, foe example, the tight grouping of parallel roads around the Peripherique would cause the navigator to assume we were on the correct road when in fact we had moved over by one or sometimes two roads.
Battery life looks right on the new unit, are there any other advantages?
Thank you. |
Posted: Wed Jul 04, 2007 3:05 pm Post subject: |
There will be a vast difference between the 2 receivers. The original Emtac used the SirfStarII chipset, and the new one uses the SirfStarIII. This has had a number of years development and is much more sensitive and less power hungry.
As to the differences it will make in real life in Paris: you should find there are less drop outs due to lack of signal, but the positioning on close roads can still suffer for a number of reasons, not just the accuracy of the signal/receiver, but also the accuracy of the maps. _________________ Mike Barrett |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Thu Jul 05, 2007 7:31 am Post subject: Smallest BT GPS |
What currently is the smallest retail BT GPS. I saw one in a pendrive last week, but don't speak japanese. |
Darren Frequent Visitor
Posted: Thu Jul 05, 2007 7:48 am Post subject: |
It's difficult to measure as we'd need to know the 'volume' to compare a pendrive agaianst a more common format device.
I have a Navicore package here with a tiny BT 30g GPS receiver that measures 6.4 x 2.2 x 1.5cm.
![](https://shop.navicoretech.com/imagebank/65.jpg) _________________ Darren Griffin |
lem Occasional Visitor
Posted: Thu Jul 12, 2007 4:42 am Post subject: WAAS Activation? Vs. GlobalSat 359? |
Hi Mike,
Thanks for your excellent review of the Emtac Mini-S3!! It was very helpful!!
I have two questions that i've been trying hard to find the answers to, could you help me out?
If I buy the cheaper version of the device from Transplant's website, can I apply the same software patch that you used to enable the WAAS on it?
How does the mini-S3 compare with the GlobalSat 359 ?
Thanks for your help |
tomthompson Frequent Visitor
![](modules/Forums/images/avatars/1833591624384b98188954.gif)
Joined: 26/08/2003 15:43:37 Posts: 386 Location: Southampton, UK
Posted: Thu Jul 26, 2007 2:07 pm Post subject: |
Darren how is the navicore bluetooth gps
Read somewhere that it can be used as a wired GPS using the usb cable as well as bluetooth
And somewhere is selling them cheeeap
might be worth as a backup as mine is a few years old now _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ? |
