Pocket GPS World :: View topic - 44 channel GPS receivers
Howarduk
PostPosted: Thu Jul 26, 2007 1:28 am    Post subject: 44 channel GPS receivers Reply with quote
Hi Guys
I have always had a wired GPS receiver, but I'm now thinking of buying a BT one. I have seen whilst surfing around BT receivers with 44 channels. Is this a gimmick, or do they work better than the 20 channel ones ?
I'm open to all suggestions for BT receivers.
Howard
Ipaq 214 WM 6.0
TT6.030
CF-BC337 GPS
Active Synch 4.5
MohairSofa Calendar+Today Plug-in Ver.2.5.2
Softwinter Storage Tools Ver.2.0 ppc 420
Pocket Informant 9.01 build2390
Sprite Back up Ver 6.5.4 build 16
PostPosted: Thu Jul 26, 2007 8:24 am    Post subject: Reply with quote
It is a gimmick in some respects, the general rule of thumb is that only 12 satellites can be seen at a single point when stood on the planet - it might be possible to see more than this given additional altitude (balloon/ aircraft).
Extra channels can be handy when the signals are bouncing/ reflecting off buildings, but I wouldn't have thought 44 were required. In a few years time when/ If the European GPS system gets going then receivers may well have 44 channels but that technology is not in use yet - Mike
Howarduk
PostPosted: Thu Jul 26, 2007 2:08 pm    Post subject: Reply with quote
Thanks for that Mike.
I will go back to looking at the standard 20 channel GPS receivers. The BT-359W looks interesting.
Howard
Ipaq 214 WM 6.0
TT6.030
CF-BC337 GPS
Active Synch 4.5
PostPosted: Thu Jul 26, 2007 2:18 pm    Post subject: Reply with quote
The BT-359 is a good receiver I had a play around with one late last year - nice device, also have a look at the iBlue as well, this one will run for 30 hours of a single charge - Mike
Howarduk
PostPosted: Thu Jul 26, 2007 2:43 pm    Post subject: Reply with quote
I like the idea of a 30 hour charge. The cold start of 36 seconds is a bit off putting though.
The latest review I have found is dated jan 15 2006. Is there another latest version of the iBlue or is there just the one version would you know?
Howard
Ipaq 214 WM 6.0
TT6.030
CF-BC337 GPS
Active Synch 4.5
PostPosted: Thu Jul 26, 2007 3:08 pm    Post subject: Reply with quote
Another newer one to consider that does the 32 hour trick can be found Here and its a little more upto date in terms of review date, this is also a nice unit that works well - Mike
Howarduk
PostPosted: Fri Jul 27, 2007 1:10 am    Post subject: Reply with quote
Thanks Mike
Now that looks very nice. Your link to the manufacturers website seems to be in a foreign language and I cant access it, but after googling it I came across it being sold on ebay from the Uk at £21.99 plus £12.65 p&p which sounds reasonable.
Howard
Ipaq 214 WM 6.0
TT6.030
CF-BC337 GPS
Active Synch 4.5
alan_sh
PostPosted: Thu Oct 25, 2007 2:38 pm    Post subject: Reply with quote
I have some 32 channel ones which are great. They are auto on and auto off and seem to last for weeks if you don't use them (if you see what I mean).
I got them off ebay (search for 32 channel GPS) at around £24 each (depends on the bidding) with free postage.An example is here.
I keep them in the motorbikes and the cars - never power them on or off and they work fine and fast
ALan
23.021 (05 Feb 25)
