Pocket GPS World :: View topic - Medion 210 and the 205 software
Fatslag
Banned
PostPosted: Sat Jul 14, 2007 12:13 pm    Post subject: Medion 210 and the 205 software Reply with quote
To save people time looking around the forum for there mods on these units. Here is some info. The Medion 210 with version software 1.1 will not run the taskbar, you need version 2 or higher of the software.once you have a newer version installed on the 210 it will run just about anything on the win-ce 4.2 net system it has. The 205 however has win-ce 5 and has had a lot of the win-ce system left out so you cant run things like the taskbar however you can run a program called total commander which gives access to the file system on the 205. MY advice to you is to buy the 210 and not the 205 as it is more moddable.Tomtom runs on these but after a hard reset you need to reinstall what was in my documents and programs files as these get deleted. better run the Medion AE or PE system software as it has all the things tomtom has if not better, tom tom has 62 voices warnings medion has 95 so clearer instruction.plus better map graphics
DaveNN
PostPosted: Sat Jul 21, 2007 3:22 pm    Post subject: Re: Medion 210 and the 205 software Reply with quote
Hi Gary,
(Thought I'd post you on this thread, as you aint had a reply..... :D )
On the modded 205 (using AE), the 'proximity bar' in the right hand corner remains...regardless if approaching a POI & even in the address menu. I've done a hard reset etc etc...any thoughts??
Dave N Off Topic
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
Fatslag
Banned
PostPosted: Sat Jul 21, 2007 5:05 pm    Post subject: 'proximity bar' Reply with quote
If you mean the color bar for speedcams then this is a setting in poiwarner it can be set on or off and for distance.you edit this in poiwarner to your choice. poi overlay settings
DaveNN
PostPosted: Sat Jul 21, 2007 5:34 pm    Post subject: Re: 'proximity bar' Reply with quote
Thanks Gary....
will check settings..hadn'd changed them since the last set up...but will double check.Have noticed that after prolonged use (a drive from Lancs to North Somerset, then another to Stirling) that the top 1/2 of the nav screen just displays the background colour (no roads/POIs or whatever).
The audible warnings are fine & the road name is still at the top of the screen. A couple of power offs tends to fix it.
Have you (or any other members) had this happen? & any suggestions would be appreciated.
Dave N
Fatslag
Banned
PostPosted: Sat Jul 21, 2007 5:46 pm    Post subject: Gapi Reply with quote
Installing Gapi 3.10 should fix any screen refresh rate just run it and choose what unit you have from the gapi menu.also the total commander may need the argyshell.dll to run as well. as wince 5 has lots missing
DaveNN
PostPosted: Sat Jul 21, 2007 7:59 pm    Post subject: Re: Gapi Reply with quote
Thanks Gary,
I'm not too sure if it's actually due to screen refresh rate , when I lose the map...I lose it until I power off/reboot. But it is rare but not too rare as to be a bit of a pain. But will have a look at the files I have/track down Gapi....
I've not yet reinstalled Commander (I've had no need to as of now)....have been under orders to "stop playing with your thing.......................................& leave the Medion alone too!!"
Laughing
DaveN
DaveNN
PostPosted: Mon Jul 23, 2007 5:44 pm    Post subject: Re: Gapi Reply with quote
Hi Gary,
For some reason (?) the nav works perfectly..until I run it with POI Warner!
I then get the stalled/empty Nav Screen.
Will bang in the files tonight & have a crack at the Commander again.
As ever, your help/advice is appreciated.
Dave N
collins355
PostPosted: Tue Aug 14, 2007 4:35 pm    Post subject: Reply with quote
Fatslag/DaveNN,
can you advise how to load Total Commander and/or GAPI on a Medion 205/210 so that it runs?
Fatslag
Banned
PostPosted: Tue Aug 14, 2007 6:57 pm    Post subject: reply Reply with quote
Gapi is installed from the pc using activesysnc it will when you run it from the medion give you the option to set which medion you have along with other devices this installs a gfx.dll file in windows for correcting any graphics in the programs you use.totall commander is used on the Medion 205 as Taskbar does not work on the 205.To use total commander you will need to edit the menu.xml file in the menu folder on your flash disk so it appears in the menu screen on the sat nav program when it loads this then gives you access to wince desktop. Example
app name="app1" madatory="1"
icon posX="10" posY="125" width="95" height="68"
resource path="navigation\menu\320240\icon_commander.png" /
/icon
action path="navigation\\commander" /
/app
you will have to make your own icon for it or rename another to use . and copy total commander to the navigation folder
collins355
PostPosted: Tue Aug 14, 2007 9:07 pm    Post subject: Reply with quote
Thanks, but when I install GAPI from my PC to the Medion I get no options. It just installs into default directory on the Medion. There is no way to 'run' it on the Medion.
Fatslag
Banned
PostPosted: Tue Aug 14, 2007 9:43 pm    Post subject: reply Reply with quote
As i said above in the example if you dont have access to wince desktop or file system you need to edit the menu.xml file to include it in the menu
DaveNN
PostPosted: Thu Aug 16, 2007 8:38 pm    Post subject: Reply with quote
Ahh...but have you actually tried the nav since?? I just dumped mine in the Medion & it works fine!!
DN
22.064 (26 Jun 24)
