redsquirrel Occasional Visitor
Joined: Jan 23, 2007 Posts: 58 Location: Chandlers Ford, UK
Posted: Fri Jul 20, 2007 11:30 pm Post subject: Question for any Nuvi 660FM owners .... |
.. what is in the directory built into your unit called \Garmin\gpx. On my old 660 there was a single file, on the 660FM it looks corrupt. Here is what I see
 _________________ Red Squirrel
Garmin Nuvi 660FM
DriveSmart (pending disposal ) |
benjones Occasional Visitor
Posted: Sat Jul 21, 2007 11:56 am Post subject: |
Your unit is corrupt mate. Mine was exactly the same as soon as I bought it. I found I couldn't delete any of the files / folders either as they had invalid characters in them. Easiest way to fix is to copy every proper file and folder off the unit onto your hard drive, format your Garmin and then copy all the files and folders back. |
Posted: Sat Jul 21, 2007 12:50 pm Post subject: |
benjones wrote: | Your unit is corrupt mate. Mine was exactly the same as soon as I bought it. I found I couldn't delete any of the files / folders either as they had invalid characters in them. Easiest way to fix is to copy every proper file and folder off the unit onto your hard drive, format your Garmin and then copy all the files and folders back. |
Is there a procedure for formatting the 660FM documented anywhere _________________ Red Squirrel
Garmin Nuvi 660FM
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Sat Jul 21, 2007 2:59 pm Post subject: |
Alternatively, you can try running a "Check for Errors" on the drive in Windows, although I would recommend a full backup beforehand. This should fix the corruption problem, which, given it was reported to Garmin months ago, I'm surprised is still there... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Sat Jul 21, 2007 4:50 pm Post subject: |
swing wrote: | Alternatively, you can try running a "Check for Errors" on the drive in Windows, although I would recommend a full backup beforehand. This should fix the corruption problem, which, given it was reported to Garmin months ago, I'm surprised is still there... |
I bought mine yesterday directly from Garmin UK (my wife used to work there) and it definitely still had the corruption. A CHKDSK from Windows has indeed removed the corrupted directory.
The unit still appears to be working properly so I'm hoping the directory was not important.
Anyone know if I should copy the directory and contents over from my 660 backup ? _________________ Red Squirrel
Garmin Nuvi 660FM
Posted: Sat Jul 21, 2007 6:31 pm Post subject: |
No, although one of the directories is corrupt, there is only 1 valid file in that directory normally, and it is fine, despite the corruption surrounding it. You should still have the file (if I remember correctly it's the file containing your favourites - so if they are still there, there should be no need to copy back anything from the backup). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
inspiredron Frequent Visitor
Joined: Dec 17, 2006 Posts: 302 Location: Ellesmere UK
Posted: Mon Jul 23, 2007 10:53 pm Post subject: |
Yes - it's your favourites file! I would guess that it does not matter but you may have lost the position of Garmin Taiwan!
I tried to copy the contents of my file over but the forum complained that I was using html tags!  |
Posted: Tue Jul 24, 2007 12:01 am Post subject: |
inspiredron wrote: | Yes - it's your favourites file! I would guess that it does not matter but you may have lost the position of Garmin Taiwan!
Not only that but the Garmin UK HQ has moved too !! The forum complaining about HTML tags was the reason why I posted my original problem as a JPG image of a screen capture  _________________ Red Squirrel
Garmin Nuvi 660FM
Posted: Tue Jul 24, 2007 7:15 am Post subject: |
inspiredron wrote: | I would guess that it does not matter but you may have lost the position of Garmin Taiwan! | If you use the CHKDSK method to fix the corruption, you should not lose this file though. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
