Pocket GPS World :: View topic - Question for any Nuvi 660FM owners ....
redsquirrel
PostPosted: Fri Jul 20, 2007 11:30 pm    Post subject: Question for any Nuvi 660FM owners .... Reply with quote
.. what is in the directory built into your unit called \Garmin\gpx. On my old 660 there was a single file, on the 660FM it looks corrupt. Here is what I see
Red Squirrel
Garmin Nuvi 660FM
DriveSmart (pending disposal Sad )
benjones
PostPosted: Sat Jul 21, 2007 11:56 am    Post subject: Reply with quote
Your unit is corrupt mate. Mine was exactly the same as soon as I bought it. I found I couldn't delete any of the files / folders either as they had invalid characters in them. Easiest way to fix is to copy every proper file and folder off the unit onto your hard drive, format your Garmin and then copy all the files and folders back.
redsquirrel
PostPosted: Sat Jul 21, 2007 12:50 pm    Post subject: Reply with quote
Is there a procedure for formatting the 660FM documented anywhere
Red Squirrel
Garmin Nuvi 660FM
swing
PostPosted: Sat Jul 21, 2007 2:59 pm    Post subject: Reply with quote
Alternatively, you can try running a "Check for Errors" on the drive in Windows, although I would recommend a full backup beforehand. This should fix the corruption problem, which, given it was reported to Garmin months ago, I'm surprised is still there...
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
redsquirrel
PostPosted: Sat Jul 21, 2007 4:50 pm    Post subject: Reply with quote
I bought mine yesterday directly from Garmin UK (my wife used to work there) and it definitely still had the corruption. A CHKDSK from Windows has indeed removed the corrupted directory.
The unit still appears to be working properly so I'm hoping the directory was not important.
Anyone know if I should copy the directory and contents over from my 660 backup ?
Red Squirrel
Garmin Nuvi 660FM
swing
PostPosted: Sat Jul 21, 2007 6:31 pm    Post subject: Reply with quote
No, although one of the directories is corrupt, there is only 1 valid file in that directory normally, and it is fine, despite the corruption surrounding it. You should still have the file (if I remember correctly it's the file containing your favourites - so if they are still there, there should be no need to copy back anything from the backup).
inspiredron
PostPosted: Mon Jul 23, 2007 10:53 pm    Post subject: Reply with quote
Yes - it's your favourites file! I would guess that it does not matter but you may have lost the position of Garmin Taiwan!
I tried to copy the contents of my file over but the forum complained that I was using html tags! Embarassed
redsquirrel
PostPosted: Tue Jul 24, 2007 12:01 am    Post subject: Reply with quote
Not only that but the Garmin UK HQ has moved too !! The forum complaining about HTML tags was the reason why I posted my original problem as a JPG image of a screen capture Idea
Red Squirrel
Garmin Nuvi 660FM
swing
PostPosted: Tue Jul 24, 2007 7:15 am    Post subject: Reply with quote
If you use the CHKDSK method to fix the corruption, you should not lose this file though.
23.061 (04 Jun 25)
