Pocket GPS World :: View topic - help with POI capture on tom tom 910
Cranky_trucker
PostPosted: Sat Jun 30, 2007 11:43 am    Post subject: help with POI capture on tom tom 910 Reply with quote
installed your POI capture on my 910 last weekend. whenever i tried to add a new camera it goes through the whole process but then says Failed to Add.. any ideas anyone??
PostPosted: Sat Jun 30, 2007 2:23 pm    Post subject: Reply with quote
Firstly did/ have you got a GPS position fix when trying to use the POICapture? - if so which version of TomTom software have you got installed on your 910? - tap the sat strength meter lower right and the next screen will show the version number part way down on the right of the screen - Mike
andrzej123
PostPosted: Fri Jul 20, 2007 4:25 pm    Post subject: Reply with quote
I have exactly the same problem on my Go 910. When I want to add camera it says: Failed to add POI.
andrzej123
PostPosted: Fri Jul 20, 2007 6:09 pm    Post subject: Reply with quote
OK, My problem is solved. My TomTom Go 910: Version 6.525, GPS v. 1.21, Boot 4.86.
1. I downloaded Quick GPS fix.
2. I checked - and I had in My Western and Central Europe (v.660.1219) catalogue 128 *.ov2 files.
It should not be OVER 100.!!!
When I removed some of them to the number - 82 *.ov2 files - POICapture version 1.06G (Many Thankx to The Author) started to save cameras.!
So main solution was - not to overfill root catalogue (over 100) with *.ov2 files.
I was able to solve this problem thank: mikealder - TomTom Faq.,
thomag , Oldboy, Andy_P2002.
I must learn how to place exact link where I have read about it , and how to quote.
Smile
PostPosted: Fri Jul 20, 2007 7:23 pm    Post subject: Reply with quote
andrzej123 wrote:
.... and how to quote.
Click the quote button over any post you want to quote from, and it will open in an Edit window, ready for you to add your post and then submit. ;)
PostPosted: Sat Jul 21, 2007 12:44 am    Post subject: Reply with quote
Or if you want to quote from various places in one post, just copy the text you want to quote then click on the quote button above the reply box, paste your text and click on the quote button again. (unfortunately that won't say who the quote is from so please say so aimmediately before or after ( "Mr xyz said...").
andrzej123
PostPosted: Sat Jul 21, 2007 7:38 am    Post subject: Reply with quote
Thank you very much, I will try to do it.
I have another questions about POICapture.
1. First time when I opened it - I saw "Preferences" and "Start over" in it's menu. Now it has gone. It is possible to have it back?
2.When POICapture captures new cameras (places I add), everything is fine but eg. when I tap 30 mph speed sign in the menu, later when I am driving, it shows only camera icon on the map without this 30 mph speed limit warning on the icon.
Is it possible to see also actual speed limit on the icon - I was thinking this feature (when I am choosing different speed icons before it is stored) was done for this purpose. Am I right?
Regards
andrzej123
PostPosted: Sat Jul 21, 2007 7:47 am    Post subject: Reply with quote
It will still be in your menu, to locate it tap a camera sype and select a speed , on the last page should be "This Side" "Other Side" "Reversible" you will find Preferences and Start Over on the same page.
The speed information you enter via POICapture is stored within the POI File, ALL cameras captured by the utility will have the same icon - Mike
22.062 (12 Jun 24)
