Pocket GPS World :: View topic - Map V675.1409
Map V675.1409
graeme_symington
PostPosted: Sat Jul 14, 2007 3:17 pm    Post subject: Map V675.1409 Reply with quote
Just downloaded these maps to replace my old v650 set. i read a previous post that a certain junction on the A127/A130 in essex had been rectified. how ever my map still thinks theres a junction there.
ive switched to the correct map and its telling me its using it. But can anyone give me some specific point i could look at to see the change and confirm its actually using the correct map.
cheers
PostPosted: Sat Jul 14, 2007 3:26 pm    Post subject: Reply with quote
If you tap the satellite graphic on the screen, you will get the software version just above that point.
If you tap the version number, you will get a screen full of information, including the current Map Version/Build No. ;)
And you didn't need to Double Post.
graeme_symington
PostPosted: Sat Jul 14, 2007 3:29 pm    Post subject: Reply with quote
yep got that. As i say it says its using the correct map. id like confirm it by comparing a certain junction or new road. As someone said the a127 junction was fixed but its not on mine.
PostPosted: Sat Jul 14, 2007 8:46 pm    Post subject: Reply with quote
If you've only got one map installed, it must be!
But if you still want someone to check a junction, then can you help out by giving it's Latitude and Longitude (you can read it off the "Browse Map" screen), as you cannot locate to a road junction in the TomTom's search menu.
22.064 (26 Jun 24)
