jonnybentwood Occasional Visitor
Posted: Thu Jun 21, 2007 2:15 pm Post subject: |
As a newbie to the forums as well can I thank you for making the camera locatins so easily available.
However, please can you let me know whether it is possible to have voice alerts for the Tomtom One as oppose to sounds. If so, how is this done as I am getting confused with the multitude of posts on this topic.
Many thanks |
Andy_P Pocket GPS Moderator
Posted: Thu Jun 21, 2007 5:31 pm Post subject: |
Yes you can.
Go to
this page and choose a set that takes your fancy.
It *IS* really hard to wade through all the different places... I've just posted this using a different computer (without all my bookmarks) and even I found it hard to re-find that page I've just linked to, and I wrote it!!
We STILL could really do with a moderator or admin to edit the very first post in this thread, people are still being sent round the houses and being told they'll have to re-name lots of files, when it's all been done for them now. |
Keefer147 Occasional Visitor
Posted: Mon Jun 25, 2007 6:14 am Post subject: Visiting England from Canada - .ogg question |
Sorry if this post appears elsewhere, but...
I've installed the Single File POI on my Ipaq 4700 with TT v5 and can see cameras OK. Have set warn distance etc.
Question is...what .ogg file applies to the single file POI? Is there one that simply says "Speed Camera ahead". I've downloaded full set of Liz Whitaker from Ray's site, but not sure what to use for the single file.
Is single file option good enough btw? Or should I grab the whole lot and get the corresponding ogg files?
Thanks very much in advance! |
Posted: Mon Jun 25, 2007 6:19 am Post subject: |
Welcome to the forum, why not visit This Page where you will find a selection of ogg voice files that are ready to use (including the Liz files), also each set is correctly named to work with its coresponding POI file set - much easier to use - Mike |
Posted: Mon Jun 25, 2007 9:52 am Post subject: |
A for your question of which actual version of the database to use....
The single file is quite good to start with as it is quick and easy to install and set up. You'll soon find it annoying that you are continually getting alerts for possible mobile sites (99% of which won't be in use at the time), but YOU WON'T KNOW IT'S A MOBILE SITE! because the icon and sound/voice is the same for everything, so you'll think the database is wrong.
Once you have got the hang of it, I'd move onto the full-speed-zoned version. It's basically the same process, just repeated over and over. Once you have copied all the files (same idea - an .ov2, a .bmp and an .ogg but for every speed and type combination) you then have to go through the warn when near setup over and over again for each one, but at least you only have to do it once. When you update the database next month, you just overwrite the ov2 files, everything else can stay the same and all your distance and sound settings are remembered. |
opel Occasional Visitor
Posted: Fri Jun 29, 2007 2:30 pm Post subject: |
If you haven't planned in a route,
i.e. your driving over to a mates place which you've been to a dozen times and know the way but can't remember the road name or even the house number - you just know where it is,
then you can't program in a route.
TT will still then Alarm you to any POI's as you drive along. _________________ Opel
Computer Support and Computer Services for Berkshire and Surrey.
www.pool-king.com |
Posted: Fri Jun 29, 2007 5:52 pm Post subject: |
Erm... If you know the way so well, don't you also know where the cameras are?
Or you could always learn the address!  |
Denzelpup Occasional Visitor
Posted: Thu Jul 12, 2007 7:02 pm Post subject: ttk sound problems |
running TT6 on Ipaq hx2790 have copied the camera data base over and no problem there, have copied over the ogg files to the correct directory, and the data chk file and re assigned the cameras with sound but it still dont work and when you re assign the voices you still get the image of the bells, etc asking which sound you want. please Hellllllllllllllllllllllllllllllllllp |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Jul 12, 2007 8:46 pm Post subject: Re: ttk sound problems |
Denzelpup wrote: | ... have copied over the ogg files to the correct directory, | The same place as the OV2 Files?
Denzelpup wrote: | and the data chk file | If you are using the OGG Files you don't need to change the data.chk File.
Denzelpup wrote: | and re assigned the cameras with sound but it still dont work and when you re assign the voices you still get the image of the bells, etc asking which sound you want. please Hellllllllllllllllllllllllllllllllllp | If you are still being asked which sound you want, it means the OGG Files are either in the wrong place, or they are named wrong. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Thu Jul 12, 2007 9:20 pm Post subject: |
Did you get them from THIS PAGE?
If you did, it's just a matter of choosing a set and copying the individual files (after un-zipping) into your map folder.
If you didn't, then the least you will have to do is make enough copies to cover all the camera types and then rename them all to exactly match the names of the camera files (but with an .ogg extenson instead of an .ov2). |
Posted: Fri Jul 13, 2007 11:37 am Post subject: |
yep have done all that and changed the data chk file back to original one and it still wont work |
Posted: Fri Jul 13, 2007 11:46 am Post subject: |
a thought has just occured, I have my tom tom 6 installed direct onto my sd card and Not onto ipaq memory would that make a difference? |
MKontic Occasional Visitor
Posted: Fri Jul 13, 2007 1:10 pm Post subject: |
Only just seen this post about making your own warning files. Cool!
I decided to create my own files, and although it sort-of works, I do have a little problem. This is what I did...
I created a .wav file using a text-to-speech app to say "Warning, gatso". I then converted it to a .ogg file and copied it to my PPC, correctly named for an ordinary GATSO and in the correct folder. I then deleted the existing warning and then added the new one. To test it I set a route and ran the route demo. As it approached the camera, all it said was "Warning". A little bemused, I went through the whole process again, but this time I only got it to say "Warning gatso" - no comma so no pause between the words. However, when running the route demo it only said "Warning ga". When I tried it a third time with "gatso", all I got was "gats"
I get the impression that there is a time limit for spoken warnings. Has anyone else experienced this? Or is this maybe just a feature of the route demo? I started looking through all the posts in this thread, but with there being 28 pages I soon gave up.
Any help would be appreciated. |
Posted: Fri Jul 13, 2007 1:49 pm Post subject: |
There probably is a limit, but it should be much longer than that!
Some of the ready made ones on the OGG files page say something along the lines of "Bing-bong.. Warning, Gatso ahead, thirty miles per hour" so yours should be fine for length.
Incidentally, there might be one that suits you on that page anyway. One of the single-file version ones might be what you need.
Otherwise, check that your .ogg files are mono and 22050Hz sample rate and when you run your demo, keep the speed at 200% or less. |
Posted: Fri Jul 13, 2007 2:38 pm Post subject: |
finally have managed to get it to work , eventually had to un install TT altogether reinstall and then copy all files across and it works fine.
thanks all for ya patience |
