dgbisset Occasional Visitor
Posted: Sat Mar 24, 2007 2:51 pm Post subject: Nuvi 660 Bluetooth problem with Samsung D900 |
Currently have a Nuvi 660 and Samsing D900 mobile.
Bluetooth worked fine up until a few days ago. Now when the Nuvi finds the phone and connects then, after about 10 seconds the Nuvi disables bluetooth. I try re-enabling but the unit just seems to hang for ages.
Is the Nuvi faulty or, am I doing something wrong?
Any help would be appreciated.
Cheers |
alexberry Occasional Visitor
Joined: Nov 15, 2006 Posts: 17 Location: Edinburgh, Scotland
Posted: Sat Mar 24, 2007 9:38 pm Post subject: Re: Nuvi 660 Bluetooth problem with Samsung D900 |
dgbisset wrote: | Hi,
Cheers |
Hi... I have exactly the same issue with my wife's D900. The nuvi660 connects fine with my Motorola v3i, but behaves exactly as you say when trying to connect with the Samsung D900.
I'm afraid I don't have a solution. I assume that the fault lies with the D900, rather than the nuvi, given that my mobile pairs fine.
Looking forward to hearing if there's any resolution to this issue from others.
Alex. _________________ Alex Berry,
Edinburgh, Scotland |
Harveyc Occasional Visitor
Joined: Oct 23, 2006 Posts: 31 Location: Nr. Emsworth
Posted: Sun Mar 25, 2007 10:46 am Post subject: |
If you haven't already tried updating the BT firmware within the unit I would give it a shot as it cured a colleague's BT woes. There's a BT hidden menu with a update button, then reboot. If you've already tried this, then sorry I can't think of anything else. |
Posted: Sun Mar 25, 2007 11:17 am Post subject: |
I tried updating the bluetooth via the hidden menu - it didn't seem to make a difference.
Although, I have now tried pairing the Nuvi with a Nokia 6230 and it works fine. The bizarre thing is the Samsung D900 worked up until a few days ago.
I've logged a query with Garmin and await their response - I don't hold out much hope though.
Cheers. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Sun Mar 25, 2007 11:50 pm Post subject: |
same problem with nuvi 360 and samsung d900.
some very heavy duty googling led me to believe that it is the phones firmware that causes the issue and an upgrade will solve this. some even deeper googling found me the firmware files along with software for carrying this out. however, you need a special data-cable for the phone and it gets mentioned numerous times that flashing the phones firmware will result in the IMEI being set to all zero's... not a problem for some networks but o2 (who i'm with) block all phones with 'blank' IMEI numbers so that stolen phones that have been 'flashed' won't work...
basically we're stuffed! weird thing is though the other month my phone suddenly started working fine for 3 weeks and then stopped just as suddenly...
MaFt |
kangaroo802 Occasional Visitor
Posted: Wed Jul 11, 2007 4:58 pm Post subject: |
Harveyc wrote: | If you haven't already tried updating the BT firmware within the unit I would give it a shot as it cured a colleague's BT woes. There's a BT hidden menu with a update button, then reboot. If you've already tried this, then sorry I can't think of anything else. |
where is the hidden menu? |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Thu Jul 12, 2007 11:12 am Post subject: |
kangaroo802 wrote: | Harveyc wrote: | If you haven't already tried updating the BT firmware within the unit I would give it a shot as it cured a colleague's BT woes. There's a BT hidden menu with a update button, then reboot. If you've already tried this, then sorry I can't think of anything else. |
On a 660 get to the 'console' display (on map, tap the speed display at Lower RHS when NOT following a route)
The next step seems to be a little variable - so persist.
Tap and HOLD the centre button of the top row of three along the centre of the display (should make sense with unit in front of you - can't remember what it displays). You will need to hold for 5-10 secs.
(On my 660 I find I get better response if I tap and hold the top edge of this button)
This will pop up the 'hidden' menus.
BE VERY CAREFUL NOW - ONE WRONG ACTION CAN STUFF YOUR UNIT - NO RESPONSIBILITY ETC...
Go through the menus using the NEXT button until you get to the BT Status menu - the Update button is the available. Warning - I don't know what this does as BT updates are automatic when new versions of the firmware are made available from GARMIN
On the Status display it shows the hardware version. Mine shows HW100-SW280 - which I take to be V1.0 h/w and V2.80 s/w - which was the latest release I downloaded.
If it just reloads the existing copy of the fimware stored on the nuvi - then there may be a way to downgrade the BT stack -but I wouldn't recommend it without confirmation _________________ Phil |
Guffnuts Occasional Visitor
Posted: Fri Jul 13, 2007 12:45 pm Post subject: |
Just to reiterate points already made. I've just upgraded to the D900i and the BT will not work on my 310.
It connects fine and i'm able to make calls by dialling them manually, but thats it. (dont know about answering them yet)
As soon as I try to send my contacts or look at call history the unit completely freezes, the phone takes ages to disconnect and i have to reboot the 310 completely.
BT firmware has been updated to the latest and still no joy. |
Posted: Fri Jul 13, 2007 1:18 pm Post subject: |
Check the firmware level on the phone - yes I know it's new - but my last new phone (Nokia) was shipped with a firmware release 3 whole numbers out - that is it shipped with V2.xxx and when I checked on the Nokia site it was at 5.yyy Made quite a difference to it's operability with my nuvi 660
Also - edited in -
The failure to be able to use last call lists from the nuvi is odd as this is simply just a list of calls made from the nuvi - it does NOT copy over the logs from your phone (at least it never has for any of the 4 phones I have used with my 660). It would point to the fact that the BT connectivitiy you have with te nuvi is very basic.
Check what type of BT data transfer your phone uses. My N72 uses the OBEX profile - and it was this that required an application to be loaded on the N72 to successfully move the contacts to the nuvi. Being a Symbian phone you get the flexibility to do this sort of thing - with non-smart phones you may not be as lucky. _________________ Phil |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Jul 13, 2007 2:03 pm Post subject: |
philpugh wrote: | The failure to be able to use last call lists from the nuvi is odd as this is simply just a list of calls made from the nuvi - it does NOT copy over the logs from your phone (at least it never has for any of the 4 phones I have used with my 660). | It does copy this over for many "normal" phones, although smartphones, eg Nokia / Symbian models stand out as not having this support. Also, even without this, it may be trying to access the contact list to put a name to the number, which again you wouldn't normally see on a Nokia smartphone.
Kinda strange really - you pay extra for the extra functionality of a smartphone, and yet something as basic as decent car kit support is missing... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Mon Jul 16, 2007 10:44 am Post subject: |
Sod's law would have it, that i connected the 310 to the PC to update the BT firmware, but I had the latest apparently.
I thought i'd try and connect again and try and send my contacts and shock horror.....it actually worked. No hang ups or freezing. I dont know how the phonebook works in the D900, but its managed to duplicate every number that appears on the 310. |
locksmith Lifetime Member
Posted: Mon Jul 16, 2007 12:16 pm Post subject: |
Been having problems with my sony erricson K800i and nuvi310. Spent so much time and money talking to garmin that I've given up. Latest firmware/softwares loaded and although the phone connects up when it dials out it just hangs without making the call.
The annoying thing is it originally worked just fine until the nuvi had a small problem and updating the unit software caused all the problems
This is quiet possbly the last garmin unit I buy |
Posted: Tue Jul 17, 2007 11:34 am Post subject: |
Guffnuts wrote: | I thought i'd try and connect again and try and send my contacts and shock horror.....it actually worked. No hang ups or freezing. I dont know how the phonebook works in the D900, but its managed to duplicate every number that appears on the 310. |
you don't need to send your phonebook to the nuvi - it picks up the phone book when you connet. if you add a new number you'll probably find you only get one instance of it until you 'send' the phonebook to the nuvi - then it will be duplicated
MaFt |
Posted: Wed Jul 18, 2007 12:40 pm Post subject: |
MaFt wrote: | you don't need to send your phonebook to the nuvi - it picks up the phone book when you connet. if you add a new number you'll probably find you only get one instance of it until you 'send' the phonebook to the nuvi - then it will be duplicated
MaFt |
Thanks, that would explain the duplication. Just figured it would be the same as the D600 where you had to send the phonebook across. |
Hamie Regular Visitor
Posted: Sun Jul 22, 2007 8:09 pm Post subject: |
swing wrote: | philpugh wrote: | The failure to be able to use last call lists from the nuvi is odd as this is simply just a list of calls made from the nuvi - it does NOT copy over the logs from your phone (at least it never has for any of the 4 phones I have used with my 660). | It does copy this over for many "normal" phones, although smartphones, eg Nokia / Symbian models stand out as not having this support. Also, even without
Not built in... But you can download a program from Nokia's website for the Nokia 810 (Nokia hands free kit) to install on nokia smartphones. It adds phonebook download. And supports the last calls bits & pieces...
Unfortunately the latest BT on the Garmin seems abit flakey on it... Previously it worked without too many problems. The current firmware seems to 'forget' how to pull the details now & again... Until you make a phonecall from the Garmin... Then it works again... But only for calls AFTER the call made from the garmin.
Quote: |
Kinda strange really - you pay extra for the extra functionality of a smartphone, and yet something as basic as decent car kit support is missing... |
But not gone completely... Search for Nokia_810_Contacts_Sync.sisx |
