Pocket GPS World :: View topic - RAC Sat Nav
RAC Sat Nav
cheekymonkeybob
PostPosted: Tue Jan 16, 2007 3:56 pm    Post subject: Reply with quote
Does anyone know if the route 66 navigate 7 europe map will work with the satnav110, and will it fit on to the original memory card?
stevest220
PostPosted: Wed Jan 17, 2007 8:52 am    Post subject: Route 66 Britain map Reply with quote
I don't think map will work with RAC Satnav 110 unit, but I don't think the map will fit on the SD card supplied (I tried to update speed camera database, very small file, but SD card full).
Where did you get the Europe map
thesouthtoonarmy
PostPosted: Sun Jan 21, 2007 9:18 pm    Post subject: Reply with quote
The Navigate 7 PPC maps are the maps you need to purchase for the RAC Sat Nav, the memory card needed for most of europe (will allow about 4 country maps)is a 512 card but for all the maps to fit on this card you would need to remove all other language option other than english, a simpler solution would be to use a 1G card and all maps, POI's ect will fit.
follow this link to route 66 site and the europe map needed
http://www.66.com/route66/products.php?cid=UK&sec=7&ssec=1&prodid=2240
stevest220
PostPosted: Sun Jan 21, 2007 10:16 pm    Post subject: Tks Reply with quote
For the info,a 1GB card it is then.
Steve
royk69
PostPosted: Thu Jun 07, 2007 2:31 pm    Post subject: rac 110 sat nav Reply with quote
Sad well i have copied the speed camera data base for route 66 into poi on my rac sat nav 110 , popped out to test it went past 2 speed cameras and nowt nothing nil, all the files are sat there very nicely among preinstalled poi files but somehow i dont think there going to stop me getting points Laughing Out Loud
rayle
PostPosted: Fri Jun 08, 2007 11:44 am    Post subject: Re: rac 110 sat nav Reply with quote
Have you tried in "POI" to "Add as POI" and then add "POI Alarm"
If you are using the Route66 camera update, you may find a large number are wrong, one area where it is obvious is the Thames Estuary near to Southend, if you zoom in on the map you may well see warning on the river and some in the North Sea, just a case of the minus sign missing on the coordinates, it takes time but if you can see them in POI Editor, then put a minus on the longtitude they then are shown where they should be.
I have written to RAC and they are looking at the problem, mean while if you are usin the RAC filesI suggest you delete them and use Camera files found on PGPSworld, as they are probably more uptodate.
Ray
rayle
PostPosted: Fri Jun 08, 2007 11:45 am    Post subject: Re: rac 110 sat nav Reply with quote
Ray
gx100
PostPosted: Mon Jul 02, 2007 8:13 pm    Post subject: please can anyone help Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad basically memory card of my rac satnav 110 just died and i did not have backup of anything. could anyone be able to share their copy of SD card...
thanks in advance[/b]
rayle
PostPosted: Thu Jul 05, 2007 12:37 pm    Post subject: Reply with quote
Hi Gx.
If you can let me know how to contact you, I will be happy to send you a copy of the latest version.
As this is a large file I can send it by Pando, instruction are on the email, a very small download to use it.
Ray
[/b]
PostPosted: Thu Jul 05, 2007 2:18 pm    Post subject: Reply with quote
Ouch! Sharing copyright software is frowned on in this forum...
rayle
PostPosted: Thu Jul 05, 2007 2:27 pm    Post subject: Reply with quote
OK.Thankyou and Point taken, knuckles rapped.
can only suggest in that case, a phone call to 01302 72006.
This is RAC/Nutools, ask for Andrew Harrison who is very helpful
gx100
PostPosted: Thu Jul 05, 2007 5:58 pm    Post subject: Reply with quote
rayle wrote:
Hi Gx.
Ray
[/b]
i just got copy of sd from john i believe he got it from you. seems to be working fine now. thanks for response.
lugnut
PostPosted: Wed Sep 12, 2007 8:23 pm    Post subject: RAC 200 Reply with quote
would this software work on my RAC 200 sat nav, i bought it few days ago and am quite chuffed with it. Very Happy
PostPosted: Wed Sep 12, 2007 9:47 pm    Post subject: Reply with quote
The compatibility table (HERE) lists the RAC110, so you could well be in luck.
The instructions "click me" sends you to HERE
PostPosted: Wed Sep 12, 2007 9:53 pm    Post subject: Reply with quote
Andy I don't think that link to the instructions is correct (too many ctl v per chance? or are the links wrong on the index page?) - try This One as it details the set up for Route 66 and the RAC devices, the other page just links back to the one I have posted - Mike
Page 2 of 3
