Pocket GPS World :: View topic - ICN520
ICN520
DUDSY1
PostPosted: Tue Jul 03, 2007 5:17 pm    Post subject: ICN520 Reply with quote
After unsuccessfully trying to upload data onto my ICN520,I then found that when I tried using my sat nav there was no map data available.Does anyone know how to rectify this please.
Dean
PaulB2005
PostPosted: Tue Jul 03, 2007 5:28 pm    Post subject: Reply with quote
Can you give a more detailed explanation of what you did and what happened?
mostdom
PostPosted: Tue Jul 03, 2007 8:09 pm    Post subject: Re: ICN520 Reply with quote
Dean
Total stab in the dark! Read this.
Dom
PaulB2005
PostPosted: Tue Jul 03, 2007 8:20 pm    Post subject: Reply with quote
Most likely this - CLICK HERE
PaulB2005
PostPosted: Wed Jul 04, 2007 10:12 pm    Post subject: Reply with quote
Moved from duplicate thread.
DUDSY1 wrote:
Still unable to upload camera data onto my icn.And now my directions are given to me by an american voice.As you can see i'm not the best on a computer think i'll just put it down to experience.Thanks to everyone who tried to help.
Dean
PaulB2005
PostPosted: Wed Jul 04, 2007 11:57 pm    Post subject: Reply with quote
According to the manual Page 66 - CLICK HERE Right Click and select Save As... to download a copy.
Language Preferences
1. From the Main Menu, tap Preferences.
2. From the Preferences screen, tap Language.
The Language screen will display.
3. To change your language, including the voice scheme used for voice-guidance during
navigation, select your preferred voice scheme from the Language box by tapping the left or
right arrows or using the left and right sides of the 4-way toggle.
4. To enable Voice guidance instructions during navigation, select the Enable check box.
5. Tap Save. The Main Menu screen will display.
The PGPSW database instructions for the ICN520 are CLICK HERE
Tell us where you get to and what problems you have.
PaulB2005
PostPosted: Thu Jul 05, 2007 10:52 am    Post subject: Reply with quote
Moved from another new thread.
Thanks Paul,but ever since I upgraded my icn the only options I have in my language settings is English[US female or US male]
As for the camera data I can't get any further than stage four,I choose the file but the camera data doesn't show.
Thanks again.
Dean
PaulB2005
PostPosted: Thu Jul 05, 2007 10:53 am    Post subject: Reply with quote
You are using POIEditor to open the files?
DUDSY1
PostPosted: Thu Jul 05, 2007 2:38 pm    Post subject: ICN520 Reply with quote
Have managed to re-install english voices on my system.Thanks for the help.But still unable to install camera files.After I download from site I right click and "save target as".then I extract the file,I connect my sat nav to smart st2005 and click on map,then P.O.I,I then choose file and when I then press open it always says unknown file format.
Any ideas please
Dean
PaulB2005
PostPosted: Thu Jul 05, 2007 2:42 pm    Post subject: Reply with quote
Are you definitely trying to open the ASC files and not the bitmap files or any other file?
Did you see this note in the instructions
Note: Newer versions of the software, by default, ask for 'Files of type: CSV Files (*.csv)' You might have to put *.* or *.asc and press 'Open' in the File Name window in order to show the asc files.
Do you see the ASC and Bitmap files as shown in the picture in step 4?
mostdom
PostPosted: Thu Jul 05, 2007 2:49 pm    Post subject: Reply with quote
As above see Here
Dom
PostPosted: Thu Jul 05, 2007 3:02 pm    Post subject: Reply with quote
you could try renaming the files from .asc to .csv - see if that helps
DUDSY1
PostPosted: Thu Jul 05, 2007 3:41 pm    Post subject: ICN50 Reply with quote
Thanks to all,have know managed to open file in window.Do I need to download every asc. file and what about the bitmap files?
If i do need to download all must I give different names to them.
Dean
mostdom
PostPosted: Thu Jul 05, 2007 3:57 pm    Post subject: Reply with quote
If you have one of the grouped databases (seperated by type, speed zoned), using poi manager you must upload each file seperatly and you will need to rename each as they will overight each other. When you upload each file there will be several options to play with including the .bmp attachment where you can select an aproptiate image to be displayed.
Enjoy!
Dom
PaulB2005
PostPosted: Thu Jul 05, 2007 4:16 pm    Post subject: Reply with quote
Step 9 says
9. You will need to repeat this process, from part 4, for each camera type you wish to install onto your unit.
As you install each one you can see what type it is (GATSO, MOBILE etc). Name them accordingly.
22.063 (19 Jun 24)
