Pocket GPS World :: View topic - Go700 Unable to find Speed Cameras in POI
gbaguley
PostPosted: Thu Jul 05, 2007 12:06 am    Post subject: Go700 Unable to find Speed Cameras in POI Reply with quote
Have recently upgraded TT software and also decided to download Speed Cameras from this site. I have loaded the 4 files ov2 and bmp into the Western Europe map folder but the Cameras do not show up in the POI listing
I have TT ver 6.52 / European map 675
Any help or ideas appreciated!
PostPosted: Thu Jul 05, 2007 12:28 am    Post subject: Reply with quote
Have you already got other POIs loaded? - there is a limit of 100 and if you have more than that, the new ones won't show. Have a look using Windows Explorer and count how many files ov2 you have in the Western Europe map folder.
gbaguley
PostPosted: Thu Jul 05, 2007 5:27 am    Post subject: Reply with quote
Have only got 10 or so ov2 files in the map folder, thats why I am confused.
PostPosted: Thu Jul 05, 2007 6:35 am    Post subject: Reply with quote
Double check which map folder you have put the ov2 and bmp files into, then make sure that the same map is the active one, Change Preferences/ Manage Maps/ Switch Map.
Unless your unit is a brandnew One XL Europe you must have added the map to the device at some point? - Mike
PostPosted: Thu Jul 05, 2007 7:40 am    Post subject: Reply with quote
Ah, that'll be the answer Mike. Previous map folders are called Western Europe (904Mb), and/or Western_Europe-Map (1.27Gb), but v675 map folder is called Western and Central Europe (1.67Gb). Strange though, the 675 map is too big to allow a previous map to be on there, so it shouldn't be a case of switching maps. Unless, gbaguley you obtained the cheaper Western Europe v675 map (926Mb), which will add on the hard Disk rather than replace the previous map.
What's the name of your map folder/s and how big is it/ they?
22.071 (03 Jul 24)
