Pocket GPS World :: View topic - London Heathrow M4 Extension.
Paul317
PostPosted: Tue Jul 03, 2007 11:05 am    Post subject: London Heathrow M4 Extension. Reply with quote
I have recently purchased a Tomtom One XL with 675.1409 maps. Looking at the map around Heathrow the M4 Extension into Heathrow is shown as the A408 and if ask for a route from Central London to Heathrow it takes me off the M4 at J3. Not being familiar with this part of the country I am not sure how long the Heathrow Extension has been around but it shows up on my 2004 version of Autoroute Express and would appear to be the best route to Heathrow from the east. Is this just an example of Teleatlas mapping being bad or is there something about the M4 Heathrow extension that I don't know about?
PostPosted: Tue Jul 03, 2007 11:34 am    Post subject: Reply with quote
I just tried a route here and it correct takes me along the M4 and off at M4/J4 along the A408 (Link Road) and into Heathrow. Are your maps TeleAtlas or Navteq?
Google Maps also know the link road as he A408, Navteq don't appear to indicate any designation.
SpikeyMikey
PostPosted: Tue Jul 03, 2007 12:05 pm    Post subject: Reply with quote
I've just calculated 4 journeys to each of the existing terminals from Chiswick and Terminals 1, 2 & 3 journeys take me via M4 J4 Spur road A408, the Terminal 4 run takes me off at J3 and down the A30.
I haven't got the same maps as you but thought that maybe the fastest option wasn't set, you're not asking for the shortest route are you?
Mike
Mike
PostPosted: Tue Jul 03, 2007 12:10 pm    Post subject: Reply with quote
J3 would be correct for Terminal 4 which is on the Southern side of the airport.
SpikeyMikey
PostPosted: Tue Jul 03, 2007 12:14 pm    Post subject: Reply with quote
I realise that Darren, I was just pointing out my results.
Sorry for the confusion Wink
Mike
Mike
PostPosted: Tue Jul 03, 2007 12:23 pm    Post subject: Reply with quote
Not at all, I meant to say that perhaps the OP had planned a route to Terminal 4 in error?
thebinman
Banned
PostPosted: Tue Jul 03, 2007 12:24 pm    Post subject: Reply with quote
The One XL uses Teleatlas.
Paul317
PostPosted: Tue Jul 03, 2007 5:23 pm    Post subject: Reply with quote
Interesting replies - thanks. I have the Teleatlas maps. I used 'advance planning' and input 'city centre' London as start and entering 'city centre' Heathrow as destination I was offered London Heathrow Airport, which I accepted. I have now redone it using POIs 'Heathrow Terminal 1' and 'Heathrow Terminal 4' as the destinations and it routed me via J4 in both cases.
When the Heathrow POIs appear on the 'pick a destination' screen you can only see 4 'London heathrow airport: termi.......' entries. After a bit of experimenting I found them to be listed in reverse numerical order. My extra wide XL display didn't help me here Smile
PostPosted: Tue Jul 03, 2007 5:42 pm    Post subject: Reply with quote
If you tap'n'hold the POI the full Text will be revealed.
Paul317
PostPosted: Tue Jul 03, 2007 5:49 pm    Post subject: Reply with quote
Thanks for that Darren. Useful piece of information!
PostPosted: Tue Jul 03, 2007 8:49 pm    Post subject: Reply with quote
...and if you don't want to select the item you've "tapped and held", slide your finger off to the edge of the screen before lifting it up. Smile
Paul317
PostPosted: Wed Jul 04, 2007 8:10 am    Post subject: Reply with quote
Thanks Andy. Something else I didn't know, which I will find useful.
22.062 (12 Jun 24)
