Pocket GPS World :: View topic - PROBLEM RESETTING SAT NAV
TRACEYLEA
PostPosted: Tue Jul 03, 2007 9:03 am    Post subject: PROBLEM RESETTING SAT NAV Reply with quote
CAN ANYONE HELP I HAVE A GARMIN STREET PILOT I3 I HAVE PUT SOME POI ON IT THEN THE UNIT FREEZES I HAVE TRIED RESETTING IT. THE MESSAGE COMES UP DO YOU WANT TO ERASE DATA I PRESSED YES THEN IT ASKS YOU WANT LANGUAGE YOU WANT THEN IT FREEZES AGAIN DO ANYONE KNOW WHAT THE PROMBLEM IS THANKS : Confused
PaulB2005
PostPosted: Tue Jul 03, 2007 9:08 am    Post subject: Reply with quote
1) Please stop SHOUTING
2) You have posted a question about a Garmin i3 in a TomTom forum - I have moved it.
3) You may have loaded too many POIs - how many categories did you load?
There is a warning on the PGPSW POI page that states
Special Note to i3 users: DO NOT TRY TO INSTALL MORE THAN 85 POI CATEGORIES AS THIS WILL CAUSE YOUR UNIT TO FAIL TO BOOT! If you have a card reader make a backup of your Micro-SD card to PC before downloading these POIs. If you have a newer model with no transflash card then you should use POIs on a separate TransFlash card to avoid any possible corruption of the internal memory.
PaulB2005
PostPosted: Tue Jul 03, 2007 9:20 am    Post subject: Reply with quote
Received by PM
THANKS FOR MOVING IT FOR ME. IS THERE ANYTHING I CAN DO TO RESOLVE MY PROBLEM. I THINK THERE ARE TOO MANY POI BUT WHAT CAN I DO ?
PostPosted: Tue Jul 03, 2007 9:30 am    Post subject: Reply with quote
if you have the original i3 with memory card then you can use a card reader to remove the poi file (Garmin\poi.gpi)
if not then maybe best to contact garmin
22.064 (26 Jun 24)
