Pocket GPS World :: View topic - Garmin Nuvi 660 updated firmware v3.8
PhilGarmin
PostPosted: Mon Jun 18, 2007 10:21 am    Post subject: Garmin Nuvi 660 updated firmware v3.8 Reply with quote
Garmin have updated both the 660 firmware to v3.80 and the bluetooth firmware to v2.8.
660 firmware updated to 'increase screen sensitivity'. Cant feel any difference though.
Bluetooth firmware updated using webupdater but had no notes.
No operational differences yet found.
Good Luck all.
Garmin DriveSmart 76 with Alexa
GJF
PostPosted: Wed Jun 20, 2007 11:07 am    Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 Reply with quote
Good Luck all.
I have so far found the same - no obvious difference.
If anything the sensitivity on the screen seems worse as i'm tapping a couple of times rather than once as before! Confused
TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver
redsquirrel
PostPosted: Fri Jun 22, 2007 9:05 am    Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 Reply with quote
I appear to have lost the ability to use the end of a pen as a stylus. Nothing happens and I now have to use my finger Sad
The warning for a couple of speed cameras I passed yesterday never sounded. As I haven't checked all the 660's settings I cannot yet blame it on the firmware upgrade.
Red Squirrel
Garmin Nuvi 660FM
DriveSmart (pending disposal Sad )
philpugh
PostPosted: Fri Jun 22, 2007 2:11 pm    Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 Reply with quote
Perhaps the update was to ensure there were less chances of mis-keying? I notice you need to use deliberate finger pressure now. This may stop me mis-keying the GARMIN-lock number and having to switch off and on - which I see as a good thing.
Phil
Hamie
PostPosted: Sun Jun 24, 2007 10:53 pm    Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 Reply with quote
Hmm... Hope so. The touch screen on mine is pretty pants really.. I get annoyed at the number of times the 'U' key comes up when I press something else... Often something on the otherside of the screen, so I know it's not just my cack handedness.
philpugh
PostPosted: Mon Jun 25, 2007 10:41 am    Post subject: Reply with quote
Sounds like a fault to me - give Garmin a call.
Phil
philpugh
PostPosted: Mon Jun 25, 2007 10:42 am    Post subject: Reply with quote
Phil
Hamie
PostPosted: Mon Jun 25, 2007 3:03 pm    Post subject: Reply with quote
Yeah... Garmin Support... An OxyMoron I think... I'd expect their support for this to be about as good as their support for the GTM-21. i.e. nonexistent.
PaulJSmith
PostPosted: Mon Jun 25, 2007 4:48 pm    Post subject: Reply with quote
My screen is now too "unsensitive" since this update. I have called garmin to complain but I don't expect a reply anytime soon.
As for the bluetooth update - the only thing it seems to have done is messed up the call logs. They used to reflect only called received/made/miised from the Nuvi. Now it seems to pick up the lists from the phone but on my phopne the list bears no resemblence to the list presented on the Nuvi.
What a major leap forward from Garmin. Keep up the good work.
philpugh
PostPosted: Mon Jun 25, 2007 5:03 pm    Post subject: Reply with quote
Not noticed that change. It's still appears to record the calls made and received via the nuvi - but I will keep my eye on it Police
I did have to reload the contacts list from my older Nokia phone (6680) after the BT upgrade - as I did when I first paired it. My newer N72 does it automatically at each connection, due to a Symbian app that needs to run on it to get functionality with the Parrot chip set in the nuvi.
Phil
GJF
PostPosted: Mon Jun 25, 2007 9:23 pm    Post subject: Reply with quote
I get this when i add postcodes and address's to my favorites, it often mistakes a letter for "U" even when well away from the position of U. Confused
Since the update I have to admit on two favorites added, this hasn't happened yet. :D
That's how i see it.
TomTom Go 60
alexberry
PostPosted: Mon Jun 25, 2007 10:10 pm    Post subject: Reply with quote
It seems that the Bluetooth Firmware update has resolved issues with the Samsung D900 - it now seems to pair up and work OK.
Hooray!
Alex.
Alex Berry,
Edinburgh, Scotland
PaulJSmith
PostPosted: Tue Jun 26, 2007 6:44 pm    Post subject: Reply with quote
More than deliberate finger pressure for me. Sometimes the unit moves on the mount I have to press so hard. Also, using the finger to drag the map around is much harder now.
Pants if you ask me. Preferred it the way it was.
Hamie
PostPosted: Tue Jun 26, 2007 7:44 pm    Post subject: Reply with quote
Makes you wonder if the programmers actually use one of these things on a day-to-day basis, or only at their desk. The UI is crap for a driver (No space for speed, yet space for a bloody button bringing up the MP3 player!), no traffic except via multiple button pushes, traffic sorted by distance from a random endpoint, rather than distance from your position and now impossible to use touch screen...
GJF
PostPosted: Wed Jun 27, 2007 11:31 am    Post subject: Reply with quote
I'm now getting used to this and am beginning to prefer it.
I do have a Brodit mount so not having a problem with the mount moving, but adding an address or favorite is a lot easier than before.
After the initial setup i prefer not to fiddle with the unit after i have set off unless i'm forced to, so keep my "fingers" to the steering wheel.
TomTom Go 60
23.091 (03 Sep 25)
